Will poplar keep for a year
KYrob
146
KY
My neighbor has 2 poplar trees he wants me to cut down. Since they are just across the fence I figured I would split and stack them for 2012/13. Will the wood be OK til then? I have heard that poplar rots pretty quick.
Thanks,
Rob
Popple is pretty much like any other wood. split and stacked, and kept dry, it will keep for a long time
I know for sure one year (and it still looks good) and I hear two or three years.
Poplar will be fine as long as it has been split. It might even be fine if left in the round depending on the weather.
Matt
CSS it will last three years (maybe more but have seen it last three).
On the ground in rounds...punky within a year.
in my experiance keep it dry and off the ground. I love poplar if im going to be at home to feed it.
Last year I burned poplar that the PO had cut and stacked into rounds several years before--I'm guessing around 5-6 based on the level of detritus on them and the fact that I'd had the property for 2-3 years at that point.
The bottom round was gone, for the most part and the top was pretty punked out. The stuff in between? I'd burn it the rest of my life if I could get it. And it hadn't been split.
I'm in interior Alaska, and I think our wood grows a little differently here, because the wood that other people call garbage wood is what we depend upon to heat our houses: birch is the good stuff, and spruce comes next, and poplar/aspen/cottonwood is considered at the bottom of the heap. All I know is that stuff was golden, and I got up to almost a 12 hour, heat-producing burn (not just `oh look, there are a few coals left) out of the poplar. I spoke to someone who said he'd been heating his wood for more than 20 years and all he burned was poplar. He cut it down into four foot lengths, stack them like lincoln logs, and the next year he'd cut to length and split.
Even if it wasn't good wood, I'd ask myself if this was a good neighbor.
Keep it dry and it will last for a long time. Around here the 100+ year old log cabins and covered bridges were made out of yellow-poplar. A few boards get replaced here-and-there, but they are still standing.
The beginning of the season I was burning poplar cut/split in March of 09, I'll burn the rest of it in the spring. Only knock on it I have is the amount of ash it leaves behind.
poplar or tulip?
woodmiser said:
poplar or tulip?
Yes, there is a big difference between poplar and tulip. And the log cabins were also sometimes built with popple but they did not last long. With yellow poplar it is a different story.
My area is infested with big yellow poplar (tulip).
I split and covered 2 cord of Cottonwood over 2.5 years ago. It's now burning as perfectly as Cottonwood burns (fast and hot). The splits show no signs of decay. The trick is to get them off the ground, keep air spaces between stacks, and definitely cover.
Tony, I thought you had burned all that cottonwood. Well, it should for sure burn well now.
Dennis:
That Cottonwood tree was huge, we will be burning that stuff at least through next year. I almost never fully load the firebox with Cottonwood, I use it mainly for stretch fires and to reheat a cold firebox.
Dennis:
And we know cottonwood can get pretty big. Here is a picture of my wife.
The OP has yet to respond. What is all the talk about cottonwood?
It's yellow poplar best I can tell. It will be an easy drop as there's nothing in the way. Have to move the rounds about 25 yards to my yard and split and stack em'. I cut 3 big locust yesterday at my farm and split and stacked them today. I have decided that I really need to finish building my splitter or just go buy one. I took my 362 yesterday and I could feel it last night when I got home. Took my axe today and split all I had cut and stacked it and I am sore all over. Forgot the camera but with the mild weather we have had so far, I figure I am 3 years ahead of the game right now. Anyway, I'm waiting for the ground to freeze before I cut the poplars. Not sure when that will be as it was near 60 today and supposed to get cold for a couple days and then warm back up in the 50's. Crazy weather but it beats a bunch of snow.
Rob
Yellow Poplar is a tulip tree... not poplar at all. It's a Magnolia. It does punk up easy if let lying around on the ground. Not great heat output but burns like pine.. crackley.
