So here are a few more details about my installation.
The stove is installed in my basement which I dug myself over the last 5 years on a part time basis. A picture shows the initial install in 2009 when I installed the stove initially to protect the construction zone from freezing, I had no insulation at all at this time
And I loved it. So we completed the works and kept the stove, final picture shows result.
I repost some pictures about the new convection blower installed this week (under warranty) and the restrictor plate also done this week, including pictures or related docs send with the plate package.
Last night, I completed the mag test after I managed to get a Mag gauge (mechanical type).
I have to add here that from the floor level in my basement, the ground level outside is about at 6ft. Then, when I measure the chimney outside, it measures 32ft from ground level to the tip of the chimney. It's a masonry (brick) type of chimney in which I installed a 4 in stainless steel liner. In all there are 4 elbows: 3 - 90deg and 1-45 deg.
Having said that, I did the mag test routine: clean stove, leave damper slider in original position (ie. wide open), lit stove, let burn at setting #5 for 1 hr and took readings. I was at 0,27-0,28 in H2O
So I played with the damper to finally end up with damper plate completely closed: I am now at 0,17 even with combustion air trim set at 1.
I think the long rise is probably creating a strong suction into the stove?
Anyhow, I can now see that I moved away from a brisk flame pattern to a quieter flame that fills the stove nicely. I think I will throw far less heat through the stack in the future. I am very happy with all the tuning done recently!
Thank you to the contributors of this forum who helped me a lot with diagnosing my problems and improving my installation.
