Right now I'm heating my shop via in-slab radiant heat. I've got an EKO 60 in the shop that heats both it and my house. Hot water from the boiler first goes to the house (hot water baseboard) and then I'm pulling the shop's radiant off the return from the house. I've got two radiant zones in the shop and I'm keeping the thermostats set at about 66-67 degrees. (total of 7 loops)
I use a Ranco aquastat to power the radiant zone controller. If the returns to the boiler drop below 150 degrees, the ranco cuts power to the radiant zone control. Once return temps get back up to 158 or so, the Ranco powers things back up.
Once the slab is up to a nice temperature, there's hardly any temperature drop between the radiant supply/return. When the zones quit calling for heat, the slab will cool just enough so that the radiant goes through numerous on/off cycles before return temps remain high-enough to keep the ranco from shutting things down.
Here's my question.....should I just set the shop's thermostats to just have the radiant run all the time? Would this then make the radiant almost transparent to the system? It seems to me that once up to temp, the slab would just serve as big heat bank that hardly pulls any heat from the water.
Thanks,
TH
Thanks,
TH
