New Jotul Oslo Owner Needs Help
TuffGong
23
East Coast of Wisconsin
First off, thanks to all of you for all of the great information I have read on this wonderful site. It has been so helpful for someone new to the game.
I have a ranch home that is about 2,000 sq ft or so with a Jotul Oslo in the basement. Existing wood stove (what a dandy) was there when I moved in a year ago. I have a high efficiency gas fireplace on the first floor (wife's decision). The house is shaped like an L with the stove basically in the middle of the house.
I am looking for ideas to help move the heat thru the house. I am really impressed with the Jotul and the heat it puts out. Simply with the door to the basement open it seems like a lot of heat moves upstairs, which is great. However, I have two cold air returns that run directly above the stove and one main heat duct adjacent to it. I'd like to move that heat thru my ductwork, either with the furnace fan on or some kind of venting solution. I have been experimenting, blowing a fan on the stove, still need to put a fan on the top of the staircase, etc. Any suggestions would be appreciated.
Also, I realize I probably should have put the stove upstairs but I have very small children and the basement location is the safest for them. The basement is a walkout which makes it very convienent to bring in wood, get rid of ashes, etc.
Lastly, my biggest problem has been wet wood. The kid, and he was young, that I bought my oak from this year definitely did not season it for the two years necessary. Being a first timer, I foolishly bought it without so much as a simple split or two to check it out. When I split it, the moisture is noticeable. If I do purchase from him again it will be simply to stack it and season it on my own. His claims of the wood being seasoned were far from it.
Thanks again to everyone, this site is a treasure chest of information. I really appreciate it and to anyone who has any suggestions thank you!
Welcome to the site... It is a great place.
You are already ahead of the game knowing that you should season it for 2+ years. Around here you can't buy dry wood, and all the dealers claim it to be "seasoned" which is a relative term and means nothing. Most members here are at least a year ahead on their wood supply, which I am still working on doing myself.
As to moving the air around, it is easier to move the cold air than the hot air. Try placing a fan at the top of the stairs blowing down.
I am still fairly new here, and I am sure others will chime in soon with more advice. :)
Welcome,
Great stove. As far as moving hot air from the stove thru the ductwork and returns, it has been discussed here with negative results. I think the general consensus is that the air would cool too much while moving thru the ductwork to be effective. Maybe your setup would work better, I'm sure others will comment soon.
Most here will tell you, fuel is VERY important. Use the search function here. Do your research. There are some tips and tricks you can do to make your unseasoned wood a little more bearable, like drying some inside by the stove or mixing it with dry pallet wood.
Good luck.
One more thing about the location. I don't know how much trouble it would be to move it but many here with little ones use a hearth gate and are very happy with it including myself.
I've got a 2 year old, and we were very worried at first as he liked to play with the stove during the summer when it was cold. We considered getting a hearth gate, but it was not practical in our situation. We always tell him that it could be hot and to be careful. Whenever the stove is hot, he stays away from it. When it is cold, he still plays with it. He hasn't even been close to getting burned.
I definitely need to try a fan at the top of the staircase. The air movement there is really something.
My other question was if I cut out part of the cold air return and the hot air would naturally rise upstairs as the ducts end right to the right of the stove.
