Oslo install questions
mtjulien
10
Hudson Valley, NY
Hi,
I brought home a used Oslo 500. My chimney guy is installing it in five days. I'm concerned about a couple things so I'm hoping someone here can reassure me. My installer put in an insulated liner, 25'. It pops out into an existing brick hearth. A few things happened with the installer that have a me a little nervous. Little oversights like putting the liner in on 12/23 and leaving the pipe open with no cap. After cleaning the soot and the living room generally, it was time to do Christmas quick. So I put decorations in the hearth and never thought about checking for an open draft. This thing has a massive draft and for two weeks it was hoovering my heat straight out of the furnace into the great beyond. Without going into detail a couple other things happened, that, while not the end of the world, were a little careless.
I have a couple main concerns. One is the connector pipe safety and the other is what to watch for in a block off plate.
The Oslo height is 28.5". I have 31.5" from the floor to the liner (less after tiling) and just 1" between the back of the stove's flue pipe and the brick wall of the hearth (less after tiling). (He originally told me that my Jotul 3 would be "perfect!" in there and that is even taller.) He seems very confident but it seems so tight to me. Here's my first question: are clearances to combustibles not needed when a surface is adjacent to stone or brick?
He plans to cut a length of pipe to fit and custom make a "collar" that will be closed with two removable screws (so the stove can be pulled out for cleaning or maintenance). This will run straight off the stove flue pipe and connect to the insulated liner. My next question is, is this enough of a run, 2-2.5", between the stove and the liner? Are there minimum lengths required here? I don't see it on the online Oslo manual on the Jotul site. But it's a little hard to decode in paces too. Q3: Is there any other manual/literature for this stove, or is that it? Q4: Does it seem like the collar will withstand the heat?
I did convince him to install an insulated block off plate. Q5: If the pipe runs 2.5" and is surrounded by brick and an insulated block off plate, will that be ok? Q6: is single wall pipe ok? I was reading through the Oslo install posts and see that there is a short leg kit. Q7: Would that help? I'm flying blind. My install guy is really nice, don't get me wrong but there have been a few red flags and I'm nervous. Thank you very much!!
He plans to cut a length of pipe to fit and custom make a “collar†that will be closed with two removable screws (so the stove can be pulled out for cleaning or maintenance). This will run straight off the stove flue pipe and connect to the insulated liner.
-If being abel to easly removing the stove is something you really want i would highley recomend a two piece SS tee.
My next question is, is this enough of a run, 2-2.5â€, between the stove and the liner? Are there minimum lengths required here? I don’t see it on the online Oslo manual on the Jotul site. But it’s a little hard to decode in paces too.
-No minimum distance to SS liner.
-Nothing else to my knowledge besides a dealer install guide. Which is just a shortened version of the manual.
-If he uses a good quality SS their will be no problems with heat and longgevity.
I did convince him to install an insulated block off plate. Q5: If the pipe runs 2.5†and is surrounded by brick and an insulated block off plate, will that be ok?
-Long as the insulation is firerated.
-Yup. Short leg are used only if the stove wont fit into your fireplace.
Q7: Would that help? I’m flying blind. My install guy is really nice, don’t get me wrong but there have been a few red flags and I’m nervous. Thank you very much!!
-Again only if the stove won't fit into the fireplace or would help the installer make his connections.
It sounds like he is trying to do a good job and paying attention to your concerns. Good to hear that a block-off plate will be installed. He should be sure that the horizontal connection to the liner is pitched uphill slightly, at least 1/4" per ft..
Thanks Chelmsford!
Yes, I will need to pull out the stove when I clean it and when my tiles come in. Since the liner is in a straight line with the stove flue, all the creosote and soot will dump right unto the (?) baffle.
I'll ask my guy about the two piece SS tee. Will it work in the 2-2.5 inches of vertical that we have to work with? And there is only 1" to the back hearth wall. The flue from the stove is pointed up not out toward the back.
So you think the stove placed 1" from the brick is ok? I don't know what is behind the brick. My house is 230 years old solid Dutch construction and what I can see of the chimney from the basement, it's beefy. But, preferring to err on the side of caution, say there's only one course of brick and some wood back there, is one course of brick enough insulation? I will be laying tile on top of the brick too. I think there is a back heat shield available for this stove. Should I consider that and/or a shield of the pipe. It's just so tight, I don't know if it will help.
Thanks BG!
I'm not sure if slightly pitching the uphill horizontal connection to the liner applies here? Maybe I'm not seeing it but the flue from the back of the stove shoots straight up into the liner.
The brick and whatevers behind it will be fine.
Thanks Logger! :)
I have another question.
The wood panels surrounding the brick hearth are 1-1/8" thick. Am I reading the manual correctly, that I don't have to protect wood 1"+ thick?
Also, my mantel extends outward 10.5". Do I not need to protect that?
Thanks!
We love pictures, can you snap a few of the setup for us and post? Im sure youll see the 1000 words promised in the idiom.
