Jared said:Oh yea, by the way I already replaced the green "ON" switch for a constant onoff switch. My finger was sore after half a cord. I figure it's probably better for the motor anyway cause it does'nt have to start and stop all the time.
also it was a little herky jeky the first couple of hours. I sprayed the sliders with wd40 and and wiped it down. It slides alot smoother after running nearly an entire day. I think it just needed a little breaking in.
Jared said:Buying somthing then taking it back is called renting. In wich case Home depot is the worlds largest rental Shop!
You can't buy a sandwich and take it back or a soda for that matter.
Granted, home depot is a large and succesfull company; I guess That gives everyone the right to buy their new equipment with the intention of taking it back used. One could say it's like stealing windows xp. Bill Gates does'nt need my 300 dollars neither does home depot. But last time I checked People work at both companies that have famillies and pay living expenses. If their company does well then they can get regular pay increases to keep up with the cost of living.
Enough of my rants I 'm taking my splitter back.
kwburn said:Elk, I know you have a better splitter and don't have to make this decision BUT....
if you had $300 to spend and had to live with the splitter you bought for 5 years would you buy the 6 ton Iron Horse or the 4 ton Ryobi??
Reading your past posts it sounds like the Ryobi may be built better but the the 6 ton verses 4 ton makes for a true difference in real world use.
Any thoughts?
