Thanks again, guys, all good advice. I like the idea of a pro saw, and is it wrong to say that I like the classic look of a Stihl saw?
Ponying up for some added durability and longevity is no problem for me, however, I want to be sure The thing I'm thinking now, however, is going used. What's your take on this one? http://grandrapids.craigslist.org/grd/2937937174.html. I figure I can bargain him, maybe? I tend to think of a new saw like a new car. Once you drive it off the lot, it looses a lot of it's value. Although not as much comparatively, of course...
The 026 Pro is a good Saw.
It looks battered. But a little elbow grease and some paint for the bar..... It will be like new. Or if you can get it for a little cheaper, you will almost pay for a new Bar. Makes an old saw look brand new.
I wouldn't call that "battered". But for $300 I'd prefer it to say MS260 Pro on it. Same saw really, just an age difference. 026's can vary in performance depending on which carburetor was on it. Stickers are cheap & easy to replace and I actually like the bare metal look on a bar. I say get it for $250.
I thought the same and it says this in the stihl documentation:
ms290 2.8kw/3.8bhp
ms261 2.8kw/3.75bhp
It makes no sense but the my ms290 16" is a year and some change but started using it this past fall. The ms261 18" is only several months old and it will cut faster and pull you into the wood better than the ms290! In this case I think the numbers are a mistake....And the mpg is better also ;-)
That is I say stock for stock! My saws are not modded except for the spark arrester is removed which is nothing. Chain speed I think is the key! So I think I explained why it maikes no sense.
End or rant!
HP specs seldom tell the story....it is in the cylinder/piston porting among other things. A great example of this are the 290 and the 261. One is an anemic pig and the other is a hot rod.
Well guys, it never hurts to ask a seller how much he'd be willing to go down. Here was our text conversation prior to me committing to go down and take a look. Yes, he used that many exclamation points.
Me: "How bad do you want to get rid of your saw
Him: "not that desperate"
Me: Would you be willing to talk? How old is it, how many cords did you go through with it?
Him "I think in bought in 2000 but not sure I have five saws! A new one costs around 600! I used it to cut small stuff around my house Not sure how much I actually cut!
Me: "Good information, thanks"
Him, 4 minutes later: "Its not worn out and I won't take less than 200"
Short story long, picked up my 026 pro saw for $200. Thanks for all of your opinions and help on my first legitimate saw purchase!
They are damn good saws. I wish there were a lot of them where I'm at.Are Jonsereds all washed up?
There are alot of them on CL and I am considering buying a bigger one but...
Thanks for the thread.
Now I know.
I've had my Jred for 20+ years and it still runs great. Binds up when burried in big logs so I want to go with a stronger saw.
