Door Glass Cleaning: Anyone thought of...
Swamp Fox
94
Went out today to buy a few things and bought a bottle of "FAST ORANGE" hand cleaner. Had some time to kill and got to reading the back of the bottle and read that it is petroleum sovent free, is a citrus cleaner, and removes the following: "...toughest dirt, grease, grime, soils, resins, printer's ink, paint, glue, rubber cement, gasket and tile cements." It comes with or without pumice. I was wondering if anybody has tried any of this stuff (or the Gojo brand) to clean their stove door glass. I plan on giving it a try the next time I clean my glass. Any thoughts?
use a damp cloth dipped in ashes. cheap and it works.
Be careful using the stuff with the pumice. That stuff is very abrasive and can etch your ceramic. I use it at work alot ( without pumice) and it is a great general purpose cleaner. We tried to clean regular glass with it and it tends to streak alot. .02 worth
Ron
It seems like anything with orange citrus works for me, tried a couple of citrus products you find at the dollar store and they work great.
Well the common denominator in all those citus products is "citric acid" and a little scent for those faint at heart.
An old trick is when cleaning your grates for your barbque is to take a couple of those packs of cool-aid and add them to a bucket of hot water (I mean hot) soak the grates for about a 1/2 hour then hose them off, hardley any work......... But for the ceramic glass I'll stick to windex ;-)
I have found that if I burn between 500 to 600 surface temp, whatever is on the glass just comes off. After one season of burning I might clean the glass 3 or 4 times.
With my pellet stove (accentra insert), a damp rag seems to do the job (I figured that if damp ashes do a good job of cleaning the glass, then why not use the ashes already stuck to the glass?)
If you do use a cleaner liquid, be carefull that it doesn't contain soap (some generic / cheap cleaners do) - it will streak your glass unless you wash it off with water (double your work for no good reason)
Put your stove type in the signature block please so that others know what you're burning. The stove type can have a big influence on how clean the glass stays and how often one cleans it.
As already mentioned in the last thread about cleaning stove glass - yes, this stuff works great!
p.s. I too have found that I get no buildup at all when I burn properly seasoned wood and don't let the wood touch the glass. Then again, not all of my wood is properly seasoned.
