M
MasterMech
Guest
We are a bunch of wussies. Highbeam included.
Bunch of wussies that like their houses warm in the winter. The manly thing to do would be to freeze your balls off all winter.
Bunch of wussies that like their houses warm in the winter...
What about a hydraulic tractor mount? They make versions that run off the PTO pump and/or the tractor hydraulics if your tractor has a big enough pump.
With only a few exceptions, at the 20+ ton range, these are usually more expensive than the beloved 22-ton Huskee everyone seems to favor. So, a neat idea, but I'm not sure I see the point in them. More wear and hours on your tractor engine, and they cost the same or more as an independently powered splitter?
I know of one you could probably pick up for well under 1K. Iron & Oak PTO powered, one of the few I have seen that will go vertical or horizontal. NOS, been sitting on the lot for about 5 years. Still looked pretty good last time I was there. Means driving up this way though.
I thought Highbeam had a YouTube vid? Maybe I didn't find it?
Here is a decent one. Other than the music
More often than not, I'm moving wood to and/or from my splitter with my FEL, so a 3PH mounted splitter wouldn't work for me...unless I buy another tractor.
Maybe a good option. There's also this one from Speeco, but I know nothing about them. Most of the others I find are well over $1k, and I suspect there's a good reason for the price difference.
http://www.ruralking.com/speeco-log...303430313233&gclid=CKeUmvKVv7ICFYw-MgodIUMA4A
