I can't get my Jotul to 400 F. Suggestions?
Philipmumbles
5
Maine
Hi-
I have a new Jotul c 350 fireplace insert and I'm just on my third break in fire now. Problem is I am having a very hard time getting it to 400 F. I have tried everything almost at this point from just leaving the door slightly open to burn bright and quick, to leaving the air control half open to full open to closed.
At around 350 which is where I can get the stove to comfortably stay with a full chamber it barley heats the living room, which although its an old house we are in , is only around 250 sq feet with the French doors closed.
Being that its not that cold out yet ( we live in Maine ) I am worried I am doing something wrong or maybe even missing something?
I am burning mixed seasoned wood. Which, after reading a few threads on here is making me think its the wood that's the problem possibly.
Any ideas thoughts or suggestions would be appreciated.
Thank you.
The wood would be the first guess. Resplit a few splits and see if they are damp on the freshly exposed face of the wood. The other unknown is the chimney. How is the insert vented and how tall a chimney?
Would also help to know where you measuring the temp. Not doubting you just helps to establish a few facts first. Flue temp, glass temp, vent temp vary quite a bit.
The chimney is 25ft.
I'm going to see if I can score some well seasoned wood tomorrow from a buddy and see if that burns any hotter.
The thermometer, I've placed it on the iron that's on the glass face. Seems to get the hottest reading there. I tried it on the iron face to the left and it got an even lower reading.
I have the 550 and have my thermo about 2-3" into the upper vent. Not the easiest to see but gives a good indication of the box temp. Also have an IR thermo for checking the flue temp and to generally waste my time and complicate things and readings on the door are much lower. If your not getting enough heat, good idea to get some good dry wood.
On the other hand if you leave the door open or run with too much air you may be sending all your heat up the chimney. How long are you running before you start measuring your temp or making adjustments? Takes my box a fair amount of time to come to full temp.
25 ft should draw like a bandit. Is there a full 6" liner in the chimney?
Dry wood seems to fix alot of problems. Your on the right track.
If your wood is usable but just a little bit too much moisture make sure you start your fires with kindling. Its the kindling which will help get the stove up to temps faster and hotter to compensate for your bigger stuff being little bit too much moisture.
Once you get a bed of coals use the rake your coals forward technique, if your stove allows you too. Not sure how you load that stove.
Rake you coals forward kind of divides the stove in front half has the hot coals and the back half you can load the bigger stuff. Up in the front half with the hot coals and the dog house air feeding it from the front you can load some good dry kindling to get the stove to heat up to 400 stove top temp which should get the secondaries going and the heat up front should be helping dry the bigger stuff in the back.
Looks like your just shy of getting the secondaries lit off, once secondaries fire heat should go up faster for you.
https://www.hearth.com/talk/threads/rake-coals-forward-and-stove-start-up-pictures.80659/
Reactions: bostock
My thoughts are wood first and thermometer placement next. is the wood dry? and is the thermometer placed right and is it working ok>??
I like what others have said about condition of the wood. Just last night I experimented with the two predominant type I have. Blue spruce and lodgepole pine. A buddy of mine had mentioned that the blue spruce doesn't burn as well. The experiment showed that very well. Struggled to get the stove to 450 with the spruce but a comparable load of lodgepole on a comparable bed of coals took it close to 600 no problem.
Another way to figure out if your wood is the problem - buy one of those packs of kiln dried wood they sell at Supermarkets or cut up a few (non-PT!) 2x4s and burn those. If you can get good temps then you proved your wood is the issue.
Be very careful with the 2x4s though. A full load may cause an overfire.
The spruce will burn ok, but it sounds like it needs more seasoning. When was it cut, split and stacked?
Sounds like wet wood to me for sure.
EPA stoves need good dry wood to operate correctly.
You just have to get a moisture meter. The term "seasoned" has no definition. I got some "seasoned" wood earlier this year that measured 32% moisture content! Moisture content is the single most important factor to successful wood burning and a meter is under $20. Unless you are very experienced, it's just too difficult to guesstimate how dry your wood is. Get a meter like this one for example http://www.amazon.com/Handheld-Digital-Moisture-Content-Display/dp/B004KWAQAI/ref=sr_1_2?s=hi&ie=UTF8&qid=1351229172&sr=1-2&keywords=moisture meter and never guess again. You just split open a sample piece and measure.
I accidentally got some wood from the wrong stack into the stove the other day and it was awful. Dark fire, dirty glass. I quickly added some good wood and it perked right up. The difference is amazing.
