Unexpected results
Yes, the stone is a big hurdle. Heating it up takes time and avoiding it getting cold is also an issue.
The Heritage was just too small for my needs. I think if I would have had a Mansfield of Woodstock PH I would still have a soapstone stove. But I do enjoy the Defiant coming up to temp in 10-15 minutes. I could never get the temps that quickly on the Heritage.
To add to this, I reloaded the defiant this morning after nine hours on a high burn and the morning temp was at 400 degrees. So, it could have probably given me a 11-13 hour burn if I would have reloaded at the normal 200-300 degree temp.
Show off! :)
Be certain to dance away from the heating appliances!
Well done, BBar, for solving the old house heating puzzle and especially for doing so in such a skilled, frugal fashion. Now, what's this wood rack you speak of? Mind sharing???
Glad to hear they are keeping you warm.
The rack is one of these:
It's about 4' wide by 4' high, holds three to four wheelbarrows full of wood, costs about $40-$50, and is design neutral (it doesn't stick out good or bad). Right now it is lasting me about 5-7 days when full.
Some do not like having that much wood in the house. But for me, it means less trips back a forth, which means less dirt being tracked in and less wood dirt falling about since it is all stacked at once.
Reactions: HollowHill
Cheating huh. If your not cheating, your not trying. Or so i have been told...
Glad to hear your doing well. Course some say we are in for a nasty winter I'm sure your dance will continue when or if you fire up the encore. Nice to have it as a back up.
Sounds great BB, hope this makes life easier for you.
