Rookie question, Englander 55-SHP10 too hot even on low
Scott M
38
Blairstown, NJ
Just installed an Englander 55-SHP10. I have a 3 bedroom ranch house. The upper floor is only about 1300 square feet. With the stove set at 1-1 the house heats up to about 75 degrees. Firstly, is that normal ? Secondly, My understanding of a thermostat set up is that it goes to 1-1 setting when no heat is called for. That wouldnt work for me because I am already too hot on the lowest setting. Also, Does it regulate itself at 70 degrees outside temperature or is that only while in shut down mode. Thanks in advance for any insights.
Scott
Hi Scott, and welcome to the forum.
Just curious....do you know what the lower 3 buttons are set at? The LFF may be able to be lowered to cut some of the heat.
No, the lower 3 buttons are used to change the air/fuel ratio of the stove. Press each one and report back what number shows up for each one....for example, 4-6-1, or 6-4-1, etc.
LFF = Low Fuel Feed, LBA = Low Burn Air
"6"= low fuel feed,.... bring that down to 3 or 4
"4" = low burn air...... bring that down to to 2
"1" = your air on temp, leave that at one
This new setting will significantly reduce your heat output and your fuel consumption,... adjust accordingly.
Manufacture suggested I start at 5-1-1,.... depending on the particular fuel (brand pellets), you can adjust the first two numbers to achieve desired heat output while conserving pellets. For example with Somerset pellets (a hot and efficient burning pellet) I can run my stoves trim settings at 1-1-1,. ......but with Green Supremes I have to run the stoves trim settings at 3-2-1 in order to keep in from going out at low 1-1 heat range. Hope im not confusing you.
They control the air/fuel ratio of the stove. You obviously don't need as much heat, so we need to lower them a little.
OK, shut the stove off....wait until all the displays go blank. Then, press the LFF button, and then press BOTH down buttons at the same time until you get a 4. Do the same procedure for the LBA, and set that to 3. Never change the last one (Air On Temp)....it always stays at 1.
Re-start the stove, and let it burn for a while...see if that helps. If it's still too hot, try 3-2-1, or even 2-2-1. Be aware, going very low on the settings makes burning tricky....that's why you need to work you way down until you get a setting you can live with.
As the winter gets colder and you need more heat, start reversing the setting back closer to what it came with from the factory.
Thanks for the fast replies, this site has a wealth of info. Glad I joined.
Glad to have you here. MANY very knowledgeable pellet burners here.
You are also one of the very lucky Englander owners who also have Mike Holton on the forum, who is the Senior Service Tech at Englander (stoveguy2esw). He will pop in on occasion and answer questions or help address stove issues.
Oh,and we also LOVE pics of new installs, or as we say here, "no pic = it really didn't happen" ;lol
Adjusted to 4-2-1. Noticable improvement. Heres a pic of the install and a pic of a ton of pellets in my half ton truck. It was only about 8 miles.
Reactions: schoondog
Nice clean install Scott M,.. and if it ges too warm you can simply reach over and click the A/C on! lol! ... nice job and welcome to the forum.
Yes... That A/C does the whole house in the summer and the stove can do the whole house in the winter. Its the Climate Control area LOL... The propane company has been sticking it to me for 27 years. I should send a pic to them too...
.....The propane company has been sticking it to me for 27 years. I should send a pic to them too...
Believe me, they'll get the message loud & clear when you buy little or no propane from them. Once your sure the stove will take care of the house on the real cold winter days, you might want to take yourself off of auto delivery. Otherwise, they may stick you with a surcharge for not using enough.
You might want to photoshop a surge suppressor into that pic before the surge police see it!!
ut oh,... here come the police!
Reactions: briansol
Install looks great! Really liking the truck too !! I'm wanting to get back to a Chevy/GMC full size. Oh and on the Police side look into a surge protector for the stove, no unprotected burnin !! Sounds like your not going to have to many problems keeping warm this winter. Good luck!
Schoondog
One more hint I've learned on the forum - those bottom three numbers on the Englander only affect running on low heat settings 1 and 2.
And if you have kids - be sure to check those numbers once and a while - okay this was the second hint.
True for certain versions of the controller but not all.
ive found on mine they control more then just 1and 2
One more hint I've learned on the forum - those bottom three numbers on the Englander only affect running on low heat settings 1 and 2.........
Very true for the earlier years (pre-2004 for sure), but most of the newer units will have effects on the higher heat ranges too.
Most reliable way to find out is to call Mike H. & his guys at Englander with your make, model, control board number & revision #....then they can tell you for sure.
The stove came with an O.A.K so I installed it. Thanks for the PM on the surge protector. Ordered it up. I am running it on a generator now thanks to hurricane Sandy. The Chevy does OK with a ton in it. I wouldnt want to do it on a regular basis or for more than 30 miles or so. Got pellets at the tractor supply for $214. The Lowes and Home Cheapo were $209 but I didnt want to drive 20 miles to save 5 bucks. I am a cheap Scotsman but not that cheap
