Did the breakin fires, Now I got it up to 580 stone top to cure the paint. Quite the fire storm going on in there.
650 stove top I think thats hot enough. Im going to turn her down now. the frickin andirons are glowing. I guess there seasoned.
Slow1 the PH has the best fire show of any stove I have ever seen! Thing is the BTU's are really cranking too especially for this weather. I am looking forward to Woodstock's newest stove!
Todd , Thats what I was thinking. The chimney is outside masonry 12x12 flue 22 feet. About 20 years ago I lined it with 8 inch stainless & insulated with rock wool. This year I put a 6 inch liner inside the 8 & insulated with Perlite.Sounds like you should have more control than that. If the air was just cracked open I would hope the stove would settle down to a lower output. How tall is your chimney, maybe you need a pipe damper to slow things down but you should prolly play around with it a few more times just to see if this is a consistant thing.
