break in for Jotul C550 insert
OhioBurner©
1,535
Center of Ohio
Its cooling down now so time to get the new Rockland insert broke-in. I do have the manual but other than 'building a few small fires first' is there any more specific recommendations? A certain amount of kindling the first time? A certain temperature (and measured where)? I do have a laser IR temp gun. This is my first new stove... Just want to make sure I do it right!
Thanks!
1st fire kindling. 2nd fire, two small splits. 3rd fire, a little bit more. You should smell a little something on the last two burns. That was it for me, good to go from there. Let it cool down all the way between break-in burns. Great stove, you'll be happy with it.
Thanks for the info... about what I figured I just a worry wart I suppose. For kindling I suppose about as much that would equal less than 1 small split of wood right?
Dont beleive I have talked to anyone that has the Rockland... anything I should be aware of besides break in? Sounds like its working for you.
Pile o' wood,
I am really looking forward to my first winter as a serious wood burner with the 550. I bought the Rockland in April and only had a few small fires, but it raised the temp in the room about 9 degrees very quickly. Had only a little smell, so I hope I did it right. I guess I'll try a few more when it gets a bit cooler. One problem that I had and I'm not sure if the stove just didn't get up to temperature, but the fan on auto never came on. I'm thinking that once I get that baby cranked up it should work fine. Otherwise, I will be calling the dealer to take a look at it. Keep posting. I'm curious to see how you make out with it.
Best of luck!
I had a problem with the automatic fan also. I found that if you push the ashes to the back of the stove before you start a fire it works much better. The ashes work like insulation and prevent the sensor from recognizing it is hot enough until you really get alot of coals. Normally it will take 20 minutes to 1/2 hour to kick on. You can just turn it on if you do no want to wait. One of my fans was a little lose and would vibrate and make some racket. I just removed the bottom grill myself and put a little foam rubber around the fan an it got quite. Other than that it worked fine. You will probably find some black soot build up in the corners of the glass. Every couple of weeks I found if you just take a little newspaper and wet it slightly, put in in the ash and rub it on the glass it cleans right up. Then use a paper towel to take off the residue. YOu can put a thermostat right in the open slot on top if you want an accurate reading. If you are using an IR then point it in the slot or you will not get a good reading.
GolfandWoodNut,
Thanks for the tip on the thermometer and the fan. I have been wondering for a while where the heck I'm going to put a thermometer. I thought maybe on an insert it wasn't feasible to have one, especially on the Rockland since it sits flush. Must be kind of tough to read however stuck in the slot.
Thanks fellas. Really looking forward to it. We also bought way back - maybe april, not sure. But I didnt have my truck at the time so it sat at the store. Finally in early summer I made the decision for them to do the install and I wasnt in a big hurry so they just did it a few weeks back. I just got my IR temp gun and moisture meter for pretty cheap from Harbor Frieght. I wouldnt bet my life on thier accuracy but hopefully good enough to get in the ballpark. If you want to use a magnetic one I suppose you could stick it in the slot and then just pull it out with gloves on to check it. Would be a pita but would look better probably and atleast you would have something.
One thing I noticed... the installers took some parts apart when they routed the power cord in the unit and it seems like that temp control is loose. Does yours feel that way or did they forget to mount mine properly?
I use an IR therm. too. I aim it into the slot where blower air exits about 3" in and in the center when I take reads.
I leave my blowers on manual. Turn them on when temp. hits about 450 -500* and adjust according to how much heat I need at the time.
When you hit new high temps. in the beginning you will get the break in smell again and maybe some metal 'pinging'. All this goes away once you are burning regularly.
Don't know if you have searched old threads but there is a rather extensive one here on the 550. It has been going for a couple of years now and is full of a lot of good info.
Have fun and you are smart to break in your stove now when you can open a window to get rid of the smell.
I'll have to look for that thread. As far as break in, I'm going to be off work mon-wed so will try to do break in those days. Temp is getting perfect were its not so hot that you dont want any unnecesary heat but not too cool to have the windows open.
Thanks for the link. I had read recent posts about the Rockland but I dont think I went back far enough to see that one. I'm about half way through reading it now and had to take a break!
First light!
So far so good, I had the first fire yesterday and second today. I just used kindling and some twigs. Using IR temp gun and pointing it to the top surface of the stove inside the hot air slot, I got a peak of about 250*, towards the sides it peaked under 200. Second fire (today) I did the same but threw on a couple of real small splits and a couple branch rounds, like maybe 1.5". Peak temp hit 345* in the center, sides were less than 300. Will try tomorrow again with a bit larger small splits. Also spent most of the day chucking wood through a rented splitter. Got my big stack of rounds split for next year, probably 2/3rds of what I'll need. This year my wood might not be 100% properly seasoned but next year a should be golden. Just got to get that last 1/3rd by the end of the year.
Jaugust124 said:
GolfandWoodNut,
It is not that hard to read if you do it right. Put the thermometer in so that 400 - 450 points out, your probably want the temp between 400 and 500. So the white arrow is visible when it is in the range. Also I keep a little flashlight nearby the fireplace and just shine it in there once in awhile. It is also kind of nice to not see the thermometer on the outside of the Jotul, plus you definetly will not get a good reading unless it is in the slot. There are other threads on this, with pictures, and it works well.
Well the IR gun seems to be working out great, and I can grab it just as easy as a flashlight and can sweep it across the top a little to get a range. I'm curious when up to full temp it probably evens out but so far I have only done 3 break ins and the temp varied quite a bit from the center to the outside. They are a tad pricey but the HF ones arent too bad. I wanted the harbor frieghts moisture meter so I also got thier IR temp gun in the same order.
My wife and I are getting our jotul 550 tomorrow .. Live in mass. Gonna be in the 60s all weekend .I read a lot of forums so it looks like I will start with the 3 break in fires..I am just wondering can I do them all in 1 day or 1 each day . And do I leave the air Intake open on all 3 or play with it alittle .. Any suggestions would help , on everything from getting good overnight burns , to blower, everything ..thanks
Shawn
Thanks!
I am starting my 1st break in fire as we speak. How long do I burn for ? Do put the blower on ? My thermometer is sitting in the blower opening ..
I am . All it tells me is to use kindling the first fire and add a log or 2 the next couple fires getting it hotter. I was just curious how long I should do these burns.
The manual should have temperatures for each fire. Mine did for the castine.
It does. 200, 300 ,400 .. I just didn't know how long it takes to get it to that and if my thermometer is in the right spot
Oh, ok. Start small, for your first one, until the fire goes down to coals. That will be a good gauge for your next fire.
I did progressively larger fires each time until I did not smell any type of cooked paint odor. Open your windows when you do these first few break in fires as the odor can be overwhelming with the windows closed - not too bad but you'll notice it for sure. Keep the damper open all the way (completely to the right) until it gets going good and burns down a bit. Once you have some coals you can close it down a bit (about 1/2 - 1" to the left) and then let it burn down to nothing. Build a bigger fire the second and third time (even four if needed) until there is no more smell of paint or other manufacturing oils, etc... The warm temps are great for seasoning your insert as you can leave the windows open to exhaust the odors and not get cold.
From that point forward it's really a trial and error type of situation in order to understand how the stove works best. READ THE MANUAL often until you understand how and why everything is supposed to function. Don't close down the damper too quickly or you'll stifle the fire and it will start to die down and smoke a lot. As the fire progresses from the initial burn into coals, you can slowly begin to close the damper by moving it about 1/2" or so at a time from right to left. You won't get 8 hour burns, not sure where they got that number but it's not going to happen. You'll be lucky to get a solid 6 hour burn before the beast needs to be fed again. I work from my home and generally need to reload about every 4 hours or so to maintain a consistent stove temperature that's adequate to keep the house temp's stabile during very cold weather.
Good luck and stay warm!
Thanks man,
I have my stove thermometer but it's not reading anything ,I also have my blower on . I have it where the air is coming out .I probably should just go get the ir thermometer . I am just burning kindling ,small pieces of wood now. I guess I will just burn alittle these next few days and then start using big splits. Thanks
