Welcome to the forum penguin.
Cover only the top of the wood pile. Stack the wood on some poles or landscape timbers or (ugh) pallets. Stack it about 4' high and leave some space between the stacks. If you have a long time to wait you can stack it closer together but for most folks that option is out. Here is how we do it.
The first picture was right after stacking in April. Come late November or early December we top cover using old galvanized roofing. That can be screwed down to the wood and also we throw some uglies on top to weight it down a bit. We always try to leave our wood in the stack for 3 years or longer before burning. That saves lots of problems and also cuts down on the amount of wood we need to burn simply because there is not much moisture in the wood. This also has the advantage that we rarely have to clean the chimney because we do not get creosote.
View attachment 81780 View attachment 81781
Those are some nice stacks you have there Backwoods!Welcome to the forum penguin.
Savage, Is there an advantage to using galvanized roofing other than the weight and screwing it down?
It seems to me that the downside to using sheet metal roofing is that it is large and difficult to store being that the size is not adjustable
Do you cover all the wood, or just this years wood? I am a newbie also. I thought I read somewhere just to cover what you burn this year. I know you can get rubber roofing, actually it's called single ply vinyl roofing, at construction sites. Usually a new strip mall, large retail store, most large area buildings use it. Lots of scrap. Come to think of it, I would stop by the roofing company's yard and ask for scraps- Construction sites are harder to find these days.
how do i keep my wood dry while i wait for it to season ?
DanC,
I see you also use a tarp under your stacks. Keeps water from wicking up? Works pretty well, I'll bet?
DanC,
