webbie
Seasoned Moderator
You can use an round to oval to get through the damper and then connect it to regular liner further up.
The thing is, you have to drop it from the top - of course - because one end won't go through the damper!
Or, you simply and carefully ovalize a couple feet on the bottom end and drop it down. If the chimney is tile lined and in good condition, insulation is probably optional - of course it improves the draft....but it can be difficult in a DIY - or even in many pro installs. For instance, it won't fit down many chimneys.
The cherry picker is a good idea - getting up and down is a big part of the job.
