Englander Installation
jkbemdavis
52
WNY
I apologize for the vagueness of this post, but am hoping for some assistance. My buddy just boght a used Englander (don't know the model #) for his 1500 sq. foot home. He is planning to vent it through the wall. When he bought it there was no owners manual, so he is wondering about a small piece of PVC on the back of the stove. I am assuming that is for an air intake, and the exhaust pipe is the separate 3" pipe. Is this a correct assumption, and if so, does it matter where the pvc draws from?
Thanks,
John
No PVC anywhere with a pellet stove ever.
Download the manual, read it from the beginning to the end several times before doing a single bit of installation work.
Before even putting that used stove into a room in the house clean it from front to back, top to bottom, and left to right, following the directions provided by England.
Check all gaskets, replace those that fail or can not be adjusted for, before doing a dry run.
Dry run the stove outside, before putting the stove in the house.
Pay very close attention to the venting setup, it is critical for the proper operation and safety of the stove, do not forget the OAK, it must be installed and there are requirements on that as well.
Observe all clearances. If you have enough room you can increase them never decrease them.
you guys are great, thanks for the assist!
definately read our manual for the unit as for the "PVC" intake that is not legal, the intake must be a metal pipe 2 inch unless it needs to be longer than 6 ft in which case a 3 inch should be used
Thanks,
John
John.
Here is your manual. It will bo one of these two depending on yearl:
http://www.englandsstoveworks.com/manuals/25-PDVEand25-PDV.pdf
http://www.englandsstoveworks.com/manuals/pre-04.25-PDV.pdf
Please tell your buddy, if he is ever in the area, that I enjoy Woodford bourbon or Grey Goose vodka.
Thanks so much. You are all awesome. I will pass along all that you have when I talk to him later. I think he is considering starting the install tonight. I will have him read these posts first...
Reactions: SmokeyTheBear
Let us know how things go.
Used stoves are usually a very good deal but need work up front that the original owner didn't do and was likely the reason they sold the stove to start with.
Since this was a USED (and possibly abused) stove, I highly recommend taking the stove outdoors, removing as many panels, ash trap covers, blower motors, etc, etc, and giving it a deep cleaning with compressed air, leaf blower, etc.
