Harman P38 shut down
park4019
32
Southeastern Ma.
One of my older Harman P38's shut down; no warning. Replaced it with a spare, of the same make & vintage. I've never had any problems, with either one, they always performed great. I think i've traced it to a control board problem. I replaced the three amp fuse,[it was blown, not simply burnt out]. Same problem. The fuse holder has 120v, to one side of the holder, without a fuse in it. When I insert a fuse, the voltage passing through it, drops to .2volts. I have individually disconnected the three motors, & they all run, when powered by a jumper cord to line current. The vacuum control, attached to the auger motor works, when a vacuum is applied. The control board only has two rotary switchs on it. With out a fuse, in the holder, both switchs; "blower & feed rate ", pass line current. Any advice will be greatly appreciated.
Thanks park4019
could very well be a board......pigtail your feed motor, combustion blower, and distribution blower, see if they pop a breaker...if not, likely the board or a short somewhere in the wiring harness. Usually a board.
check for a pinched wire. That is what I have found most of the time. especially where the wires go uo and around the feeder cleanout
There should be no voltage drop across a fuse (okay, a few millivolts). Sounds like your replacement fuse is bad, too.
You may have a bad motor. One way to search for it is to disconnect all motors and ignitor, see if fuse holds. If it does, connect one item at a time and test. The bad item will blow the fuse.
All three motors work fine, when independantly connected to line current. The fuse thats in the board, came from my spare P38, which worked fine, when It was replaced by a P43. Only wire that I had a douibt about, was the feed from the back of the auger motor, to the vacuum switch.Although the vacuum switch & auger motor work. The wire was pulled tight & zip tied to a stand off bracket. Firtst chanc I get, I'll go back & double the the wiring.
Thanks very much; park4019
The fuse thats in the panel now is from the P38, [older spare unit] that is now running' in place of the problem stove. Both stoves had 4amp fuses, although every thing I read calls for a 6 amp. But, they both ran, as did the one in question, until it blew the fuse. All I had was 4amp fuses, so thats what I installed. With every thing reinstaled & plugged into house current; nothing works. New fuse did not blow.
Thanks, park4019
The replacement fuse came from the P38, that replaced the problem stove. I have no ignitor, only two rotary switchs, on the panel; [blower & feed rate]. I did disconnect al the motors & the fuse held. This one is really giving me grey hairs. The only thing I haven't checked, is the ehaust temp sensor. That will be next.
Thanks for the help; park 4019
If you have no voltage at one end of the fuse, the fuse is bad, or the clips are not gripping the fuse. You should have line voltage on both sides of the fuse. You mention having .2 volts at one end of the fuse.
Check the fuse with a volt/ohm meter or diode tester by itself Not on the board. You should have continuity (0) on ohms if good. Diode mode it should beep. Does the board smell burnt or burnt spot on it?? Again sounds like not the fuse..
Tested the fuse with a ohms meter, showed continuity [0]. although my meter doesn't beep. Board doesn't smell burnt, now visual burnt spots.
park4019.
I have line voltage at a empty fuse holder. Install a tested fuse in the holder, & voltage drops to .2volts. Fuse snaps tightly into the holder. This is driving me nuts. I've been told that the circuit board is no longer available , & i'll have to replace it with a $305.00 update.
Thanks park4019
Is that .2 volts on the line side of the fuse? If so, your cord or outlet is bad. If on the load side, it doesn't make sense that it could load down like that without blowing the fuse.
The .2v , is on the load side of the fuse holder. I tested the outlet, & it has line voltage. I just sent a e-mail to a e-bay site that gfreek mentioned. They rebuild circuit boards. Thanks park4019
I know I'm being kind of stubborn here, but how about one more check, which might save you some $.
With the unit unplugged, measure the resistance from the hot blade of the plug to the load side of the circuit just past the fuse holder. It should read about 0. I just can't figure out why the fuse isn't blowing.
Maybe there was a power surge of some sort or one of the motors drew too much amperage for some reason.......Kinda wonder what the amp draw is on them.. Might not be able duplicate what happened...
True, but that doesn't explain why he has line voltage at one end of the fuse, and essentially zero volts at the load end without a blown fuse or bad connection. Electricity just doesn't work that way.
Agree. Does not make any sense....
That's perfectly normal if you're measuring voltage across a good fuse.
One probe should be on neutral and other probe on end of fuse, AC volt setting... Assuming this how par4019 did it.
I measured, as you said. I have 0 at the load side of the fuse holder, & accros the fuse. Pluged the cable into outlet, & .2v, at load side of fuse jolder, & .2v at feed side of fuse holder.
