Help with fireplace insert
Mtnyota
24
I'm closing on my first house. It's a 1700sqft single story home with an interior heatform fireplace. Dimensions of fireplace and house layout are attached below. Climate is coastal northern ca. (30*F in the winter). I was set on the Osburn 2000 until I measured the fireplace. The brick hearth is 1.25" above the inside of the chimney, which makes the osburn unit a little too tall. (i think). I like the look of the Regency I2400 and the price point of the Osburn. I can't find the Regency online anywhere and the local dealer wants $3200 for one.
I've been considering:
Regency I2400
Osburn 2000
Napoleon 1402
Englander 13-NCI
I've been having trouble finding places online that have the various models online with a price to tell if it's in my ballpark.
Anyone have any advice?
I recently installed an Osburn Matrix, which is basically a 2000 with a different door/surround. Based on my experience, I have two suggestions.
First, check the dimensions of your existing hearth. If your drawing is to scale then your hearth probably needs to be extended to meet modern safety requirements. Mine was similar -- too small, and sitting an inch or so above the fireplace interior. I demolished what was there and rebuilt the hearth to be flush with the floor, which helped make room for the insert is generally better for us.
Second, consider a freestanding stove that can sit in front of your existing fireplace instead of inside it. I dismissed this idea out of hand when I was planning my installation, but now that I'm actively heating my house with wood my perspective has shifted. The insert fan is a constant source of noise, and inserts are inherently less efficient than freestanding stoves, which means acquiring, storing and managing that much more wood.
Reactions: raybonz
These are the only pics i have of the fireplace. The height of the opening seems to be the main issue. At only 22.5" tall many of the inserts aren't fitting. I'm checking into the units suggested so far. I appreciate the advice.
Welcome to the forum, MT.
I have a similar set up. I am assuming that the opening of the fireplace is facing the smaller area to the left?
May I suggest a free standing stove, then, against the back of the FP, facing the area to the right side of your diagram?
It will be also easier to move heat through the house. Those doorways can be tricky, if an insert is used.
Mine, pre refacing & insert install
Reactions: Pallet Pete
I don't really want to extend outward into the room due to the living room being on the narrow side.
What is the difference between the price points of the stoves? (US Stove, Englander, Drolet, ect vs Regenct, Osburn, Quadrafire, ect)
Check out the Enviro Kodiak 1700. It is only 19" tall.
Doesn't look any narrower than the room to the left.
Englander is a great stove. Love ours.
It looks like the Napolean 1402 seems like it will fit both size wise and price and is still a decent size. I'm trying to find anyone who sells the Enviro inserts online.
I believe the Drolet is between 900 and 1200 price tag.
http://www.lowes.com/pd_365186-66915-DB03120_0__
Englander is in the same range usually.
http://www.homedepot.com/buy/englan...ing-fireplace-insert-13-nci.html#.UOOBPaXv6s0
Osburn usually runs around 1500 - 2000 at least when we looked.
http://www.woodlanddirect.com/Fireplace-Accessories/Osburn-Fireplace-Inserts
I am not sure on the rest.
Pete
Thank you, what I was asking is what is the difference in the stove. I know the Osburns/Napoleans/Regency stoves are usually around $2000 for a mid size stove w/ ~2cf box. What is the difference with the lower priced stoves(Drolet/Englander/US Stove)? ( appearance, burn time, durability)
;lol My bad.
In terms of burn times that will depend on the box size type of wood and how dry of wood more than anything. Personally I have not owned any of these so what I know is mostly second hand ! From my understanding of it Englander and Drolet are very good quality Englander has excelent customer service too. I have owned a US Stove Wonderwood and it was a pos I will never buy anything US Stove again after there terrible quality and customer service. Hopefully others way in with their personall experience before you buy !
I do think if you don't have a lot of money US Stove is safe to use I am just bias after owning and disliking their stove quality and customer service others do like them. Their newer stoves look much better made.
Pete
I think I have it narrowed down to either:
Napoleon 1402
VistaFlame VF1700 (same as enviro kodiak 1700?)
I've decided the vistaflame VF1700 insert looks like the way to go. I finally got moved in and measured the chimney tiles. The inside measurments are 6" x 15" oval. What is the best way to attack this with a liner/insullation.
