Small Log Trailer Build.......
Shmudda
Burning Hunk
Dec 6, 2009
172
Western Pennsylvania
I had a need for a small, lightweight log trailer to fit into some tight spaces and still be manually moved about for loading and positioning. I couldn't find exactly what I wanted on the market so I took the time over the holidays to build this blue one.
I needed one that was small, lightweight and could haul 4-6 logs up to 8 feet long, and this is what I came up with. It needed to be low to the ground with removable side pegs, as I will be manually loading the logs onto the trailer. I know my limitations so I assume these logs will be up to a maximum of 15" in diameter or so, and cut to about 8 feet long. This trailer will handle them easily. The reason I wanted a trailer such as this is I don't always have the time to buck the logs during the felling operation and haul them out cut up. This trailer will allow me to load the logs out full size to my bucking & splitting area where I can buck them up when I have the time. I can then go out with just a saw and maul if I only have a couple hours to work, rather than getting all the equipment out and making a day of it. This trailer will simplfy the process.
It's built from 1/8" wall 1 1/2" square tubing with front tires & wheels from a Craftsman lawn tractor. The key to this trailer was to ensure it sits level while transporting the logs, so the gooseneck took a little layout time on the CAD system to ensure the height of the ball coupler vs the trailer deck.
This is the fourth trailer I built for hauling wood, three of them are pictured below. I now have a total of (5) small utility trailers (one purchased) I use around my home, each for a different purpose, of course all related to the gathering and scrounging of firewood!!
Two of the others I built are pictured below, they are the red trailers.
Craig
Nice looking trailers, Shmudda. They look professionally built!
Low, strong, and lightweight, looks good. On mine I ripped some 6" logs and fastened them sideways flat side down so I could buck the whole trailer load at the splitting station.
Very nice looking trailers and a nice Assortment of Saws!!
Have you thought about building and selling some? As Scotty said, they look pro built and if you dig doing it, then it's not really like a job?
Really nice job Shmudda. If I ever get my Boston Whaler project boat finished I know what my next project will be!
Those are nice trailers! Good idea using the old riding mower tires.
Dexter,
I have thought about it, but with the cost of materials and my time it wouldn't be worth while for anyone. The blue trailer cost was this:
$44.00 - Wheels & Tires - Ebay! I hunted a while to find these too!
$15.00 - 2" Ball Coupler
$65.00 - Steel
$20.00 - 3/4" Diameter Axle (special material to resist bending)
$15.00 - Misc Nuts, Bolts, Hardware & Wood
$15.00 - Primer & Paint
Total: $174.00
Now, add in some time for my labor, even at $10.00/hr that would put that blue trailer up to $275.00 or so. Thats why I build my own because I am to cheap to pay someone else that kind of money!!!!!:)
I would love to build these on the side, but just not worth it...........
Craig
Reactions: triptester
Shoot! Where abouts ya from? I'd pay 300 doll hairs for one! Those little yard carts about that much and prolly half the size, just saying!
Reactions: DexterDay
+1 on this - highly suggest adding some higher wood bunks so you can cut your wood to length while it's on the trailer. You will eliminate a step in the wood handling (unloading the logs), and the wood should be easier to buck up while it's on the trailer rather than laying on the ground. A bucking stand on wheels.
Nice looking trailer(s) BTW!
Reactions: AJS56
You can't have too many trailers, says the guy with 5!
Nice build. I find myself doing the same. Build a piece of equipment for a specific use. My wood (yard) trailer is no exception.
Dexter,
$65.00 - Steel
Total: $174.00
Craig
Geez, those all appear to be nicely designed and built for wood moving tasks. As has been said, very professional looking too. I'm not thinking that blue one would be hard to sell at $300 or more. I can't weld/build like that and I'd bet there are a lot of others like me who can't, but who would appreciate your skills and those trailers. Nice work..
Also... really like the deflector braces in front of the wheels on the red cage trailer. Good protection in the woods...
Thanks for the good reviews gentlemen! I appreciate the comments. Maybe I will try to sell a few on Craig's list.
AJ..Those wheel deflectors work perfectly, as they will skoot the trailer over sideways when hitting a tree, hit many so far!
Maple, I will try your suggestion sounds like a back and work saver!
Thanks again for the comments!
Craig
Nice work Shmudda. I like each one of those designs, especially the log hauler. If you were closer I would buy a log hauler from you.
A word to the wise. Be carefull moving logs that are 15" in diameter and 6-8' long. It does not take much to tweek your back the wrong way when walking on ground that is not perfectly flat. Luckily I have not had any bad injuries, but have had a few minor ones. And we all know folks who have had bad ones and some are never the same after a bad or even a semi-bad one.
A word to the wise. Be carefull moving logs that are 15" in diameter and 6-8' long. It does not take much to tweek your back the wrong way when walking on ground that is not perfectly flat. Luckily I have not had any bad injuries, but have had a few minor ones. And we all know folks who have had bad ones and some are never the same after a bad or even a semi-bad one.[/quote]
I thought I was being smart loading my truck with 6' ash logs until I %#^+=]€ my shoulder doing so.
I have no idea exactly how, because I didn't feel anything at the time, but I tweaked my back yesterday morning just spreading ashes on our icy hilly driveway. No slips or incidents - just took to hurting when I came back in & sat down to eat breakfast. And it's still hurting. Might have been the weird hunched shuffling I was doing when I was out there, I don't know. It sucks having a wonky back.
A word to the wise. Be carefull moving logs that are 15" in diameter and 6-8' long. It does not take much to tweek your back the wrong way when walking on ground that is not perfectly flat................................I thought I was being smart loading my truck with 6' ash logs until I %#^+=]€ my shoulder doing so.
Exactly why I never try and load logs, I cut it up on site and load pieces, and the really big ones I even maul where they lay. I've managed to make it to 57 without ever seriously hurting myself, don't want to now at this age! My Dad hurt his back in his early 60's, and he was never the same, just a steady downward curve till he died at 85. It affected every day of his life after that.
While all your trailers are very nice, I like the red one with the sides and tire protectors the most!
Where are you finding 15.00 axles?? I have built trailers for different purposes in the past but find my time and materials cost make it tought to constuct them cheaper than I can buy them(under most circumstances) The upside, as you know, is custom specs that fullfill the exact needs you are after. Also, you can make them a bit hardier than the available trailers.
Are you scounging for these axles used, building them, or buying them new? The axle is the toughest part for me to find at a reasonable cost to justify the build.
Great looking work BTW
Bob
Nice job. Ever built a dump trailer?
Sweet! Hey- I'm sure that everyone has a mod to suggest (everyone's a damn expert)- but is there a simple way to also use it to hold a log for cutting off a round before unloading?
Wood bunkers under the load would make this a snap.
