I'm having our chimney cleaned this coming Friday. We have a regency insert and fully lined flue. I'd like the sweeps to take a look at the cap, that should be standard protocol right?
When we have ours dine they inspect everything - flashlight inside the firebox to check for any cracks or bricks that need replaced, the chimney itself & they remove the cap & clean it if needed. To prepare we simply don't burn for 24hrs. Don't need to clean out before they get there, they will do it for you if you prefer.
Sweep came out, swept from the bottom and inspected the stove to liner connection. He then went up on the roof to inspect the top of the chimney and showed me photos. Everything is fine except he recommended furnace cement at the liner/stove junction.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
