cleaned it. It will run for about 30 min and then shuts down. I feel blowers/ hear blowers
Anybody have any real world advice? It's 6:51 AM I doubt I'd reach anyone at englander. sigh
Really ! ....... sigh.
I'm sure you will get the same responce from others here, so take it or leave it, your choice.
thanks. I'll checkDid the while thermocouple wires come unplugged from the board?
OK. This is the longest the stove has been running since last night. It's running with both comb/conv blowers going. At 2:30 I did the leaf blower (I"m sure my neighbors are happy about that). I did complete clean also. This is right around the ton mark that the combustion blower was replaced. I have never replaced/ or even removed the convection blower. It's been running on 3 4 for about 30 minutes. I've bumped it up to 9 9.Usually an overheat/overfire/overlimit is caused by a failing/dirty/improperly maintained convection blower.
do you see any damage if I keep letting it run until is shuts down?Is your convection blower oil able?
If it is it needs to be regularly oiled.
If this hasn't been done you are going to have to oil it, work the oil in, and add a bit more oil until the blower turns freely. It is also possible that it is beyond recovery.
Is there crud on the squirrel cage?
It only takes a little to reduce the convection air flow through the stove which over time will result in the stove going out and displaying an E3
Good point. I would like to try a fix. Doing that would shut my heat down, and it's the only one I've got. Since my option is to shut it down, disconnect venting and oak. I'm not even sure I can oil this thing... I was just hoping to get it to limp along...Well I'm not one to force high limit conditions without actually trying out a fix.
I pulled the conv blower. The squirrel cage was dirty but not completely blocked. I snapped a photo of the blower because I don't NOT see anywhere to oil this thing? The battery on the camera is charging and I'll post a pic of the blower.
