Mt Vernon AE - low fuel warning
Caribfan
125
Southern Maine
My control panel is showing a low fuel warning which comes on when the hopper is almost empty. However, the hopper is NOT almost empty - in fact it is almost full. Anyone know where the sensor for this is?
On the left side of the hopper. Check your control board and make sure the connection is complete. Also refer to the owners manual.
Eric
Unplug the stove. Take the left hand side panel (when facing the front of the unit) off. This will make the control board visible. The low fuel sensor is sticky tape mounted right above the control board stuck to the side of the hopper. There should be a white or yellow crayon like line the surrounds the low fuel sensor move the low fuel sensor overlapping the line so it's almost not visible and check the connection at the board when your done. Slightly moving the sensor should fix the problem if not you need a new one.
Welcome aboard Kory, its nice to have another expert onboard.
Wow another expert to this forum, that is wonderful. Welcome Kory, and look forward to reading all your posts! By the way I hope you like beer, it seems to come up in every thread here! some would even think that this is not a heart forum, but more like a online AA meeting for us drunks lol!
Reactions: will711
Thanks, and I actually just turned 21 in February so that could make it a little more interesting haha
X3. Thanks for the info.. nice to have you onboard.
Is that really needed?, get real!
Mine has done this off and on, typically I stick my hand in the hopper and move the pellets around. This usually gets to go off.
