I have the opportunity to buy hey Castine with double wall pipe for 15 feet the through the roof kit and the stove for 1500 dollars or an Oslo itself for 1500 both are used and only a year old. Any suggestions?
View attachment 113733 View attachment 113732
We have a raised ranch and use the Castine to heat the roughly 1,200 upper level - does a really nice job. We almost went with the Oslo, but on the advice of the hearth shop owner, decided not to. He felt with the Castine, we would run it hotter. With the Oslo, we would be dampening it down and perhaps creating too much creosote. Hard to tell from the picture, but the hearth is 6 feet wide . PS - we used to have the Fisher Mama Bear - when doing a re-build on the chimney and pulled the stove out, we found a crack in the back of the stove. Could have tried welding it, but after 35 wonderful years with the stove, felt a retirement in order
We don't have a damper, but I learned where the air intake is underneath the stove in the center rear. It is the size of a golf ball I would say. In am emergency, where you would like to close off air intake completely, have ready near the stove, a balled up aluminun foil ball the size of the intake hole so you can plug it up. (Safety tip I learned form some people on this site). Our pipe goes up a lined chimney. We have no trouble with draft at all, but I am thinking of adding a rear heat shield, not so much for added protection, but to have the heat radiate up between the stove and the shield rather than heating the the rear of the stove & chimney that faces outside.Diane B Thank you very much for all the helpful information. The only thing i lack on you list is the glass cleaner because i never had to deal with glass... thats half the excitement with the new stove. I just got my free sample of the super cedars last week and have not gotten the chance to use them yet. I have a pair of welding gloves that I use to load the stove but i can see where they will definitely be alot more useful with the e/w loading of the new stove. should I be putting a damper in my new chimney?
