I wanted to know if anyone has plans for a raised hearth for my Englander 30. I would like to not have to bend down as much. However, if the task is too large I might just get use to kneeling then.
Here's a table of r values for typical hearth materials. Not comprehensive material list, but on point.I am thinking about making the hearth about 2 to 3 inches high. I was wondering that since I need an r value of 1.5 for the englander 30. How many durock cement boards would I need from lowes? Is there an official value somewhere on there website that shows the r value for this material? Are there a certain kind I should get. Then, I was going to put tile on top of the cement boards and grout it together. However, since winter is approaching fast for me can I use the stove for one year on just the stack of cement boards it will look rough but I can finish the grout next summer when I have the time and income.
As I understand it, the original Durock was approved for hearth use, but the Nexgen stuff has perlite in it to lighten it, but it lost it's hearth approval. The original stuff is no longer produced. You may want to contact the manufacturer, but it looks like Durock may not be a solution for you.How can you tell if it is rated for hearth use? I want to stack it and not tile it for this winter so I wnat to make sure I do it right.
Well, you'd want to check with Lowes or the manufacturer to be sure. Maybe it's new old stock, or maybe they're even making it again. I don't know.When I was at lowes and at lowes.com the red stuff is the regular durorock and the blue stuff is the next gen my lowes has the old regular stuff. So this is hearth approved? How can I be sure is there an ansi code or something?
Mine is sitting on a hearth made of 8x8x16 cinder blocks. The blocks outline the hearth then there are cinder blocks in the center. On top and the sides have to layers durorock the it is tiled. I find this to be a very nice height for loading wood and sitting on the hearth watching the fire.
The blocks are not mortared together but the blocks next to the wall (coner install) are screwed to the wall and the durorock is mortared the blocks.Are the blocks dry stacked or mortared together?
Is it okay to put the stove just on the cement board?
Originally i put it up on one course of cement blocks cuz if you set it directly on the floor, you practically need to lay on the floor to get an eye level view of the fire. At 8" high it still was too low so i put another course of blocks under it to make it 16" off the floor. Although it still looks a bit low its acceptable. I have 2 englander 30s in 2 different locations,workshop and project house ,both with 2 courses of block under them. IF i were installing it in my living room id build a 16" OR HIGHER hearth base under it.I wanted to know if anyone has plans for a raised hearth for my Englander 30. I would like to not have to bend down as much. However, if the task is too large I might just get use to kneeling then.
From one of the posters on here they put the cement board on steel. Can I lay it just on my carpeted floor or no?
