New Stove - up to three
gitmo234
95
Oxford, PA
So, I have the Harmon PF-100 in the basement and an older manual start stove on the far end of the house.
Earlier this week my wife to be found an englander 25-PV(something) advertised. It's the 1500 sqft model and was said to be (and looks to be) 1 year old. It came with all piping (and the guy had a ton), the thimble, cover and OAK, plus a ton of lignetics pellets for $700... good deal? I thought so.
We picked it up and installed it the great room which is a bit drafty. 25 foot cathedral ceilings and gigantic 6' windows all over the place. Very hard to heat.
This brings the total to 2 stoves and 1 furnace on pellets. We ran the two stoves with a bag each set to medium.
Woke up this morning in a sweat and the house was 80 degrees. The Harmon was shut off all together. The only downside is now my bathroom is the only room is cold.
We may have over done it on the stoves, but overall it seems to be more efficient to run two stoves on low rather than the furnace. The only downside is the icy cold bathroom
Any thoughts?
Hang a micro thermic electric panel heater(aka, bun warmer) in the bathroom.
oil-filled heater with GFCI and thermostat, set to 65.
have ya beat by 1. :cool:
Very nice! I thought I was being excessive. I knew that someone here would have me beat.
The issue is simply poor construction in the bathroom. Thin walls, almost zero floor insulation and 6 skylight windows. It stays almost the same temp as the outside in the winter (without the furnace) and double the temp in the summer without AC.
So far, the largest space heaters I've tried to use have zero effect.
I'll look up what you guys have mentioned
how big is the bathroom?
Dont have a specific size but its too large. Its larger than our guest bedrooms. If it wasnt for the bathtub and toilet you could throw a king sized bed in there and have plenty of room for the rest of the bedroom furniture
do you have a basement, crawl space, what? how many outside walls?
" If it wasnt for the bathtub and toilet" it wouldn't be a bathroom, would it ?????????????
Well, if you're going to remodel it any time soon I'd think about heating the floor. We've done it in our past two houses and are getting ready to do it next year in this one. Insulate under the subfloor and finish it with tile and you'll have toasty toes for as long as you own the house. Feels great on a cold morning, doesn't cost as much as you might think, and can be done with either hot water or electric. Larger bathrooms generally better w/ hot water, somewhat smaller with electric due to cost to run vs. ease of install. Not exactly something you can heat w/ pellets, but it does take care of the one room you often can't heat well w/ pellets but want to have nice and warm. Nice for resale, too.
