Sprinter
Do you have a screen on the chimney cap? Make sure it's not clogged up with creosote. Common problem.
Right, but remember that if the wood is good and dry and draft adequate, even a small load should flare up nicely door closed. I do it all the time for small burns. Right now in fact. Smaller splits will help also, especially if the wood is not great.Fill the stove, tough to burn big pieces like that with just a couple in there. But if the wood isn't dry it's always a fight instead of being easy and enjoyable.
That first pic clearly shows wet wood IMHO. With the door and air open that wood should be engulfed in flames not just glowing like that. Maybe look for some pallets or lumber scraps if you cannot find any other dry wood. With the wood as green as it looks like you will have a hard time to get any good fire going.
Strange issue posting here with Chrome...
I agree with everyone. I need drier wood. How do I accurately test for moisture content? MY meter is sig 20%... (it is a cheap one from ebay but I feel these things should be ok regardless)
I can buy a cord from this guy but how do I make sure it is dry?
Also, any recommendations on easy and proper stacking?
I'll do that.
By the way, is it possible to get MUCH better results with a morso?
It probably wouldn't be. It just isn't economical for suppliers to take the time and expense of adequately drying their wood. If it's truly dry, it's going to be very expensive and the guy will be willing to prove it to you. Tell the guy that's what you need to do because it's essential.I can buy a cord from this guy but how do I make sure it is dry?
Sorry, but they still won't be dry inside. Bark is waterproof and wood just can't dry with bark on it. Just a few days ago, I cut down a snag that was dead for several years and it was still 35% moisture content and even starting to get punky.I have many dead trees (still standing but clearly dead for several yeas) that I can cut, split, and stack.
That depends on the species. If they are pine, for example, it likely would. But a lot of hardwoods would need more time. But it sure won't hurt to do it. The sooner the better for sure.Then even if I cut those dead trees, split, and stack them now - they won't be dry for next winter?
