I have a spot on the inside of the glass that feels rougher when I clean it. It never comes fully clean and leaves a "cloudy" spot. Does anyone have an idea how to fix this? I usually use soap and water to clean it.
Thanks I'll give that a try next cleaning.Take a damp cloth dip an end of it in the pellet ash and use that on that spot, then using a clean spot on cloth wipe that area clean. The ash is just about perfect in the abrasive department to remove condensed wood volatiles from glass.
Sometimes you gotta give the glass a full.....ah, nevermindUse a 50/50 mixture of water vinegar, best yet.
I remember reading on this forum, last year, that cleaning products with ammonia will permanently cloud the stove's window. Windex has ammonia in it.I used to have a Whitfield insert stove where the glass would start getting dirty minutes after lighting the stove. I purchased some good old fashioned oven stove cleaner and sprayed it directly on the glass at room temp. I would ipe the glass off with either paper toweling or news paper. That took all the crap off the glass. Iwould then followup that up with Windex and the glass would be sparkling clean.
Since i've since replaced the Whitfield with a Harman, I use regular wood stove glass clean clear that works fairly well.
Good thread. Thanks guys.I remember reading on this forum, last year, that cleaning products with ammonia will permanently cloud the stove's window. Windex has ammonia in it.
I haven't verified the validity of that warning, but I would err on the cautious side and avoid window cleaners.
My own preference for cleaning the window on my MVAE is Rutland stove glass cleaner. I use it weekly when I clean the stove.
As for the cloudy spot you mentioned, I haven't found anything that will entirely remove it. I tried a mild abrasive on my PDVC and it improved the transparency of the window, but it didn't remove the cloudy spot entirely. To me, it's not worth the cost to replace the window.
