Cost of fuels after all taxes
EatenByLimestone
Moderator
Staff member
Last October my electric dryer gave up the ghost and I did a fuel cost comparison for 1,000,000 btus of electricity and gas.
The usage for October of last year was:
$47.50 for 287 kwh= $48.51 per million btus
$55.72 for 37 therms = $15.06 per million btus
This makes electricity 3.22X more expensive than natural gas.
I took my bill for October this year and ran the numbers.
$45.62 for 257kwh = $52.62 per million btus.
$44.84 for 27 therms = $16.61 per million btus.
This makes electricity 3.13x more expensive than natural gas.
It looks like it closed a little. This may be due to higher taxes or lower actual usage spreading out fixed fees per btu. It looks like I'm still pretty ahead using gas.
For giggles I looked up the state average cost per gallon of heating oil. This used to be right on to what I paid when I burnt it in the boiler. The average cost was $3.836 per gallon and that works out to $27.66 per million btu. I didn't realize that oil was still so much cheaper than electricity... well at least it is in my area.
Last year I had to do all the calculations by hand, which wasn't bad, but time consuming. This year I found this site which does it for me. It also lets you calculate the cost of running a boiler/furnace per million btus and burning wood per million btus based off the efficiency of your wood/pellet stove. Check it out!
www.eia.gov/neic/experts/heatcalc.xls
Looking at fuel pricing per mil Btu is looking at only part of the picture without taking efficiency of the heating system into consideration. The spread sheet you found will also account for that. Oil used in an 80% efficient furnace, with leaking duct work may not be cheaper than your electricity at close to 100% in an electric baseboard unit. Use that electricity to run a 300-500% heat pump and even your fairly expensive electricity is cheaper to use than nat. gas heat.
Using a ground source heat pump, I save thousands each year over what it would cost me to heat with oil.
