A method that I might actually use
Dismissing that this is super easy to split wood, the principle still applies to other wood. I think it does the tire trick one better.
edit: sorry if it's been posted
Reactions: Macpolski
That is a nice improvement on the bungee method I've seen before.
Slick, now all I need are a crap load of 6-10" rounds. Where do I get those?
With the chain there for adjustment- it should work for a really wide range of sizes. That's one of the things I liked.
I've used that method, works well but eventually I would hit the bungee and break it, went through quite a few before I gave it up.
Reactions: Adios Pantalones
Its very creative. I tried that once and cut threw the bungy I was using to hold the round.
Yep,I've had the same problem with cutting the bungie. I would guess the chain could nick up the fiskars pretty good as well. I like using the tire because you can stand up rounds that aren't quite flat on the ends and would otherwise fall over.
Reactions: weatherguy
cut right thru the bungy
Okay...mus have been my phone. Sorry. Had to see...what the fuss is.
I really like the pants and suspenders. They look like moleskin but from the side they looked like pants with chaps built in. Phew.
Thats like a french maid outfit from a mans perspective.
I love suspenders on men. lol
now that's pretty cool......I too thought the belt and suspenders were interesting.....must be "a logger"
I want to see him do that with a round of sweet gum or white oak...
Nobody is suggesting that it makes the actual splitting easier, just the picking up etc.
and FWIW- white oak usually splits SUPER easy for me when green (sans knotty pieces)
