I have a bearing question on my M55 but it is a general pellet stove bearing question. I'm getting a whining/groveling sound from my convection blower. Pulled her out and cleaned. The bearing on the end of the convection blower feels kind chitty. Most of the time it spins okay but sometimes I get that day at the beach with a bearing full of sand feeling. This is most likely causing my intermittent noise. The bearing is :
LFD 608Z CL2 and it measures 8mmbore, 22mm od, and 7mm width. I'm assuming I need a shielded bearing but just wondering if there are any other considerations you guys can think of. I was thinking about something like:
http://www.grainger.com/product/NTN-Radial-Ball-Bearing-1L001?functionCode=P2IDP2PCP
but not sure if that would get her done. Also, has anyone had any luck regreaseing the raceways on shielded bearings? I've seen a guy do it with a canning jar and some SRI#2 but not sure if I should use some oil lube instead. Any help would be great. I'm not going to replace a $200 blower because of a $10 bearing. Not my style.
Thanks in advance guys.
