Vigas 60 wood placement
Newvigasowner
22
Sudbury, Ontario, Canada
Hi guys, just installed a new Vigas 60 with 1000gal storage and i seem to have a problem with my wood placement, I've read all the posts here and tried multiple strategies but the only one that seems to work for me is to load it which ever way, front to back (my wood is 16-18" long) two rows and come back after an hour or so and stir it up because the wood is all burnt close to nozzles and hung up every where else. Any ideas, should I be making smaller splits or what, i have roughly 10-12" diameter wood split in half or three. I would like to load it up 3/4 full and let er gas. Any suggestions would be great... Burning maple and white birch at 18-23% moisture, tubes are spotless and stack temps are usually 380-500°f . Thanks guys,learning alot on this site along the way. :)
I have a Vigas 40. This is my second year running it and I have found smaller splits don't seem to hang up or bridge nearly as often. This season I have the spits smaller in diameter than a pop can. A full load burns through in about 5 hours and puts full output into storage. May actually have wood until the new cutting season, which has never happened for me before.
Steve
I have the small EKO and 10 to 12 inch splits except for that occasional tough stringy culprit are too large for it to burn correctly. I would split them one more time.
Also, when you checked moisture content, did you test it on a freshly split surface? Ten to 12 inch splits take a long time to reach 20% moisture.
I feel your pain. wish I had a 30" splitter!
I split my wood about 22 to 24" I throw them all to the back. Shorties or uglies get thrown in front.
If you don't throw the wood all the way to the back.. a two footer will cover both front and back nozzles.
Probably one of the easiest ways would be load a half box to start, then rake and fill full after 90 minutes or so. Once it's really going good, it will collapse like you want it.
With shorter wood, you could probably fit in two complete rows. I tried crosswise to the nozzles.. it's ok for the very bottom row, but upper rows won't fall where you want them.
JP
WoW those are large splits. I've been splitting them down to almost 3x3" splits.
Reactions: flyingcow
Thanks guys, i will try different methods mentioned here, so far smaller splits have been working better but seams to be more work than I wished for. Yes i checked moisture after splitting wood, my maple seams to be burning better than the birch, maybe I'll try mixing them up a bit and see what happens. Thanks again guys
Also are you guys cleaning all ash and coals out of firebox before every fire to get wood as close as possible nozzles? Right now because i am only heating my shop i fire every 3-4 days so i try to burn down everything because coals just go to waste for me.
My fire box is smaller than yours with one nozzle. But no, if I do remove it all it is once a month. I will keep the area at both ends of the nozzle clean out to allow the wood to be closer to the nozzle. You will want to keep the lower chamber raked out an reach way to the back to get it all. Also rake out the gasification area.
What Pat said. I clean out the upper chamber maybe once a month.
if I happen to be around at the end of a burn.. I can rake around and get most of the coals gone, and everything burnt up.
Bottom chamber.. I clean it out before every fire. The gassification area very well, and below just kind of raking around and getting the big piles.
JP
Thanks guys, i cleaned out bottom chamber, raked the ashes to the side in firebox and split my wood into beer can size and got my storage from 90°f to 190°f in 5-1/2 hours and two loads into vigas. She gased the whole time, i had to resist opening firebox to see how it was burning but i did open lower chamber to see if it was gassing (multiple times :) I think my wood is the problem, it not being 18% with every pc. Some splits i checked today i had up to 30% moisture but mostly in the 20-26% and smaller pcs lower. I have a cord in garage now all split into beer can size.
Reactions: JP11
You'll get so you can HEAR that gassing flame without peaking. It might take a bit. I still look when it's really roaring just to say.. WOW!
