Hello everyone,
I've been a lurker for the past couple of months trying to take in as much information as possible. My wife and I purchased our home a little over a year ago. It's a fine specimen of a 1980's home. Built in 1982 to be exact.
I will attach a couple of pictures and blueprints so all of you can see what the general layout is. It's a little over 2200 sqft, currently we're heating the home with oil (Rheem 85% efficient 140000 BTU/hr) in sub 35 degree weather and a 3 ton Seer 13 Heat Pump if temps are above 36 degrees.
We just upgraded the heating system from the original furnace that was put into the house in 1985. It turns out the owner originally only heated the house with a wood stove for the first 3 years. He is a physicist by trade and said he build the house to be only heated by wood. It happens that he just got tired of lugging the wood to the stove and decided to retrofit a forced hot air oil furnace. Then after a couple of years of no longer running the wood stove he got rid of the stove.
He stated that over the 3 years that he was burning wood he would use between 2 to 3 cords of wood per season. Now after reading all the posts on hearth.com this seems a little ridiculous. But I did a little calculation with the amount of BTU's the house uses. As we have a 8 month old baby we keep temps at 72 degrees 24/7. With temps in the low 30's/high 20's we use about 30k BTU/hr. If it drops to the low teens, like today the demand increases to 40k BTU/hr. House is technically a Cape, with 2x6 construction with R19 insulation (I think.) Windows were just replaced with U-Factor 0.3 double hung vinyl windows. (Once again this is my fuzzy math, if it doesn't make sense please don't crucify me )
So now that you know a little about the house onto my question. The hearth size is 52" wide and 42" deep. The brick hearth is located in the center of the house, and it has a brick chimney that it goes up against it. I was looking at the Harman TL300 and the Regency 2400 as possible contenders for this house. I believe both require a minimum of 48". So, do they sell any hearth extenders that would match my hearth design?
I am leaning towards the Harman as it's not a catalytic stove, I've read on another site that the cat has to be replaced every 6 years of use. Are there any other stoves that anyone would recommend to be used a primary/secondary heat source in my situation, please take into account my hearth size.
Also note that the sun-room is currently 62 degrees. It's separated from the rest of the house with insulated walls. My plan was to get the stove up and running in the living room and any of the excess heat would go into the sun room via the open french doors.
I appreciate any input into our heating situation, anyway onto the pictures: (These are the pictures that the sellers Realtor took August of 2012).
Thanks again,
-Bart
Thanks again,
-Bart
