Unique splitter design
Def. NOT a pneumatic cylinder, guys. A pneumatic cylinder will stop when it sees load, build pressure, and then let fly at high velocity when load is overcome. The only way it's pneumatic is if it's a pneumatic motor driving a screw, and I doubt it's that. No way that's a pneumatic cylinder.
I think that's what it does. Look at the lines jump. What else could it be?
I think what you're seeing is a small splitter with a VERY sharp wedge powered by a separate electric or gas powered system. The "jumping" lines are the hyd lines ... Think Hurst rescue tool....
Reactions: Ashful
Ah interesting, I think you called it. Finally found the setup video again looks like it uses water as the fluid. Has a engine and pump that's about the size of a small generator. Other than that the components are all light weight and the system was expandable so you could switch between splitting long or short logs, has a different wedges including a 4 way and seems powerful. Wonder what they go for?
This maximizes the inefficiencies of every splitter I've ever seen.
I agree, what is the goal to make splitners?;lol
I don't have GC to translate. It looks as though you supply the pressure washer of your choice?
From what I can get from the website it can be purchased with a gas or an electric power head. The website has a link to a bunch of youtube videos w/ different configurations and products. There's even a hand held version similar to the jaws of life ErikR posted.
http://www.holzspalter.it/Home.8348.0.html
How about a splitter that makes it's own fuel? Not practical but kewl non the less.
I want this one personally.
