Castile combustion fan
Burd
438
Bell bell Pa.
I have a used 2004 Castile that Im restoring.
I noticed that the combustion won't shut down,
Does anyone have any Ideas?
Could you point me in the right direction on test the limit 2/ burnback protector3.
Can I put a jumper wire on to see if the fan will shut down?
Snap discs do not control the exhaust blower. Sounds like a control box issue.
OOOOoch
How does the exshaust fan know when to shut down? Is there a timer in the box
Control box has timing circuit for the combustion blower to shut down on turn off and to shut down if thermocouple doesn't send mV reading on startup to signify ignition has happened. I'd bet the control box is in need of replacement.
