Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
That video makes my back hurt just watching it. The guy is bent over splitting and loading the cart.
Why would you split, load on a cart and move to the wood pile to unload? Move the wood to the wood pile along with the splitter, split and put on the stack directly.
Yup that was me with the Case 444. You can get a really rugged garden tractor for under a grand if you keep an eye out and don't mind an old one. Mine is 43 years old and can still pull 2k lbs
Any load can be balanced on an axle. The trick is starting, stopping, and negotiating hills. Even a small grade can be big trouble for a balanced yet massive load.
A 4 wheel dump cart would be better than that and much cheaper.
My electric splitter is in a permanent fixed position, not to far from where I stack, splits Never touch the ground, they go from the splitter to the 2 wheel dump cart and then over to get stacked
It'd be a little better with a small briggs or a 2 stroke engine to make it self propelled. I'll stick with my partially restored Wheel Horse garden tractor and trailer that I picked up for $550 total.
For the times I can't get equipment in to a spot, or its going to mess up a a pretty lawn I have a 2 wheeled wheelbarrow motor driven, with the biggest tub available. I can load it up and as long as I can pick up the back end it will pull me and the load anywhere. advantage here is I can get it back in the truck on top of a load. Course there are times /soil conditions where nothing but pure grunt is the only solution. As always it nice to have the little 4x8 trailer along so between the truck bed and the trailer just about a cord a trip.
