Like this?I had an LP pipe that penetrated the firebox to feed an LP insert. Unfortunately the pipe stuck a bit too far into the firebox for the new pellet insert. I capped the LP line in the basement. Afterwards I applied a cheap angle grinder to the problem pipe in the firebox. Afterwards, I filled the pipe with refractory cement. It is NEVER easy.
Like this?
Anyone have any better ideas on how to brake the iron pipe free from the fitting. I've used two vice grips and iron pipe just spins
Couldn't you just pull the piping through the box instead of cuttingYes, like that. I couldn't just cap it because the pipe would have been too long. I suppose I am committed to solid fuels now, but I don't see that as a problem. We only have LP ($$$$) and natural gas won't be coming down the street in my lifetime.
