Best Thermostats for Lopi Pioneer pellet stove?
My suggestion is to go on-line to Home Depot and Lowes, look at their programmable thermostats and read the manuals, which are there. Look for 'swing' adjustment. If it doesn't specifically say it, it doesn't have it. I don't know about Lopi as far as millivolt goes but just about all stoves are just looking for a switch closure so millivolt would be fine. Get the simplest one and cheapest one you can find with swing. A super fancy model is just a waste of money IMHO. Turn on/ Turn off...... end of story.
Reactions: Millerthyme2g0
My suggestion is to go on-line to Home Depot and Lowes, look at their programmable thermostats and read the manuals, which are there. Look for 'swing' adjustment.....
Thanks for the reply. Ihave been doing a lot of reading on this,seems like this swing feature is a must !!!
Any body use this one?Lux-Products-TX1500E-Programmable-Thermostat?
I looked at that one very nice but a little pricey and availability is spotty, I am replacing a Honeywell programable ( all days same program, 4 program periods) with a good old ritetemp 6022 that has 5-1-1 and a swing setting (the honeywell has the useless cycles per hour) got a new ritetemp 6200 on ebay for under 20 dollars. The rite temps also has a calibration feature which I like, my thermostat for the stove is on the wall behind and to the right of the stove and reads 2 deg lower than my hydronic stat in the same room but more centrally located. The ritemp also has a couple of other features like holiday alternate pgm and copy setting to another day that are useful
I looked at that one very nice but a little pricey and availability is spotty, I am replacing a Honeywell programable ( all days same program, 4 program periods) with a good old ritetemp 6022 that has 5-1-1 and a swing setting (the honeywell has the useless cycles per hour) got a new ritetemp 6200 on ebay for under 20 dollars. The rite temps also has a calibrtion feature which I like, my thermostat for the stove is on the wall behind and to the right of the stove and reads 2 deg lower than my hydronic stat in the same room but more centrally located. The ritemp also has a couple of other features like holiday alternate pgm and copy setting to another day that are useful
Good price, not great reviews. Diggin the feed back from everyone!!!
Just curious: Why is the swing feature important with a pellet stove? I have a wifi t-stat we use for our A/C and boiler. It has a swing option, but I don't use it much. Temp seems fairly accurate.
setting the swing to about 2 deg (defaults are usually half a degree) reduces short burns consequently reducing starts and stops which cause wear on the igniter and motors
Yep, I was going to mention that all the Honeywell's that I looked at lacked the swing option and had that goofy cycles/hour, which totally is unuseable for us. You just can't beat the Ritetemp's, unless you just have money to blow. In that case, I'll email my address!
Well, you got two great reviews here! A lot of people, when you start reading reviews for just about anything, just don't have a clue of what they are talking about or what they really are doing with anything mechanical.
Lagged,
Thanks, that helps and makes sense. I'll have to keep that in mind.
About that Rite-Temp: The one with the u-snap (wifi) looks exactly like my Filtrete 3M-50 which is no longer made. I picked it up at the depot for $99 a few years ago. I have it running the boiler and central air systems. Controlling it remotely is really nice.
Skytechs swing time is 2degrees set at the factory. Some are settable and some are not...However since I have a Avalon APG which is the same as yours I will copy and paste my concern that just happened and would love it if you tell me if that is what yours does...I have a skytech 1001TH-A wireless remote thermostat. There is a wireless receiver box outside the stove. I have that on "remote". I have "learned" the transmitter. I have it set to control the temp once it reaches 68degrees. So here lies my problem. The stove is set to TSTAT. There is a +- 2degrees response temp that the remote informs the stove to either stop or start. The stove will sometimes start but once it gets to 2 degrees over 68 it just keeps going (it has gone to 78 and still no response). It never lowers the flame or it never shuts off the stove. It doesnt seem to do much if anything. Should the Thermostat and pellet stove work just like a regular furnace? My home furnace goes on and off with in seconds of reaching the appropriate temp. Is this not how pellet stoves work?? HELP!!! Or is my wireless skytech thermostat not working correctly??
UPDATE: Apparently I may have had the remote too far from the receiver?? Yesterday it started and turned off on its own. I am still skeptical and will report back any changes
I have since changed to the Skytech 3301P2 and it is working perfectly
Skytechs
If you put the receiver inside the metal enclosure, you kill the range of the transmitter/receiver link. Keep it outside for better range.
