There is only one 90 degree elbow....unless i'm missing something. Regardless it looks like i am going to have to do something "drastic". Here is a burn with very dry pine.
The flue does not seem to have a steel liner and you would benefit greatly from an insulated 6" liner. What are the inner dimensions of the clay flue?
The part that runs through the wall is a double wall insulated pipe and It looks to be 8 or 9 inch for the clay flue, if that's what your asking for. Again i am newish to all this.....as if you couldn't tell....
but connection coming off the back of the stove is still a mess.
You and me both.....I still can't figure out why the chimney is offset from the hearth.
Well there was a pellet stove there before so maybe the tie in to the chimney can be a little more "funky", don't know never owned one. There is also another "port" upstairs on the same chimney that sealed and i just found something else behind that wall.What do you think the chimney was originally meant to service?
My guess is you have no basement under that room and where your hearth sits now used to be an HVAC closet, hence the old furnace thimble in the wall and offset to the original chimney.
PS: What are your outdoor temps like?
