Avg bag per day for a pellet burner
Chelsea
2
Michigan
Hi, I'm Chelsea and live in Michigan. We recently purchased a USSC King 8500 free standing pellet burner, 85,000-105,000 btu's heats up to 2,800 sq feet. We just purchased our first ton of pellets. We are averaging 1.5 bags/day on the lowest heat setting PR-1. Is that about normal? Our house is roughly 2,000 sq foot and well insulated. This unit is free standing in our basement hooked up in our duct work going out a flu. Is there any way we can slow down the agigtator ( the thing that drops down the pellets? ) Our unit is not hooked up to a thermostat as the unit was not wired up to do so. Any suggestions or input would be greatly appreciated. One more thing, so they pull a lot of electricity?
On its lowest setting it burns 10lbs an hr roughly. I highly advise a Tstat to regulate usage. Seems silly to not have one on a furnace.
There is a control thermostat on the unit itself. What I'm saying is that it can't hook up to our regular furnace thermostat.
You better buy some more pellet's that ton will last you 3-4 weeks, and It isnt cold out yet
Reactions: Ctcarl
It seems high but it also sounds like the unit is grossly over sized for your house. I suspect unless your house is missing a wall you could have something with half the btu output. Is it cycling a lot? It should be I would think.
Reactions: Ctcarl and reallyte
You should be able to hook up another thermostat to it.
That's a beast of a stove if your BTU info is accurate. By comparison, I have a Quadrafire Mt Vernon AE that tops out at just over 52,000 BTUs, and it's considered a reasonably large stove. I might use 1.5 bags / day in it when temps outside are in the single digits most of the day, in a reasonably well insulated 40 year old home. If you're burning that much now, I think you need to focus on insulating and air sealing your home, frankly, because I can't figure out where that much heat could go in a 2000 SF home in October, even in Michigan. Even with just the stove thermostat, that's a LOT of pellets per day. By January, I can't imagine how many you'll be burning. As someone said, that stove sounds huge for a house of that size, and you likely can't even distribute that much heat effectively.
Could you post a picture of the duct work that is distributing the air or dimensions of the pipeing. Also do you have a cold air path from the upstairs back down to the stove.
Holy smokes my p35i is a 35000 btu and on the coldest days does well on my 2000 sq ft split level.also I never fully cranked her full max. at the most the number before the Highest witch I believe is 7.i think a thermostat is your only answere and as mentioned above get atleast another 3 tons to try to get you past winter.that may not be enough .
I'm also curious.. What is the temperature outside? What is it like inside?
Even on the lowest setting it sounds as if it's going through a lot of pellets quickly; and your house would be quite warm. (like uncomfortably warm)
