velvetfoot
Not a Geospring, but my Nyletherm makes more noise than I'd like, but then again, I'd like it to be silent.
Yeah, fan noise is hard to attenuate.Not a Geospring, but my Nyletherm makes more noise than I'd like, but then again, I'd like it to be silent.
It just requires the person who wants active noise cancellation to wear noise cancelling hardware in their ears...I wonder what happened with active noise cancellation with respect to fan noise? I recall that was one of the prospective applications.
My basement was in the 50's last winter and it kept up in heat pump only mode no problem.I have a question for those who have had there Geosprings for a while. I installed mine in June and it's been great. It's been running in heat pump mode since. As my basement starts getting colder in the winter how do I know when I need to switch to hybrid mode? Will I start running out of hot water? Last year my basement got as cold as 57 degrees or so. Thanks.
I have been on and off these for a while. I have one problem.
As far as having to have a professional plumber install one, what is the case if you dont have a drain in your basement. I know there are condensate pumps, but i have nowhere to run one to. If you ran a tube outside, wouldnt it freeze?
That really depends on where his Geospring is located. Many basements are humid from high water table, even in Winter. My basement windows used to have ice on the inside on very cold nights, before I airsealed and insulated.It will not freeze as there will be no condensate. If you get condensate there, your windows would be dripping with ice on the inside. If its cold enough to freeze outside, then your house is dry. Unless you have umpteen humidifiers going.
