Englander disassembly to save weight
bookpile
90
Southeastern PA
I might be picking up a used Summer's Heat 55-SHP10L tonight by myself. It's only 290 lbs so it's not too heavy. Just looking for a few ways to cut weight. I'm assuming the door should lift off and take out fire bricks. Is there anything else I can strip off of it?
Thanks
I got mine out of the back of my pickup solo... but it nearly killed my back. Bribe a neighbor with a few beers to help.
If you are going up or down steps get an appliance dolly from U Haul for $10 will make moving easier.
Thanks everyone. I just found out it is in the sellers garage so I won't have any issues loading it.
I remember when I picked up my accentra insert I was able to disassemble a lot of it to reduce the weight.
I recently move my Englander PAH to my basement and I only had my wife to help going down the stairs. I was seriously concerned as it weighs over twice what I do and I have a bad back! So I removed the door, ash pan, hopper lid, rear panel, burn pot, auger motor and auger, combustion blower and convection blower to cut everything I could. It made a big difference and I only had to replace the combustion gasket which I had on hand anyway. No one got hurt, including me for a change >>
A few days before I had moved an EP completely by myself onto my trailer, off my trailer and into position inside the house. The seller had completely filled the hopper so as a nice bonus I had an extra 45lbs to deal with! Fortunately there were only a few stairs involved, and the descent from the trailer. So I built a ramp and was able to manage with just my dolly and some straps to hold it on tightly.
Good luck with the move!
That was easy! Now I just have to drill through my 12" block wall to install it.
  • Englander disassembly to save weight
Reactions: TimfromMA
