just curious on how much wood (splits) you go thru in a day? myself seems like 10 so far today temps in mid to high 20's. not that it really matters but curious to what others use.
thanks
thanks
This is what scares me. I'm saving up cash for an nc30 to displace my smoke dragon, and after many fights have an ok from the wife to do so. Im burning a wheelbarrow load of wood a day now. If a grand later I still have an empty wheelbarrow every night. . . I may as well move the stove to the doghouse cause I'm gonna be there a loooong time!The answer that I consistently see here year after year is a wheelbarrow full.
If you just split and stacked that wood this year keep your current stove till spring unless you can confirm it has the right moisture content. It will burn it a lot better than an EPA stove. My wood is 18%-24% and I can easily tell the difference between the two ends of the spectrum. EPAs are picky from what I've read and now experienced a little for myself.I got a triaxle load of logs and added about half a cord to it. Its not going to take me till spring at the rate I'm using it now. I'm hoping to have the new stove soon after christmas though and maybe make it through the season without hooking up the oil furnace.
I had it all split last year. Spread it out a couple layers thick on pallets through the summer. Stacked it in my wood room and have run a dehumidifier for over a month now. The highest reading I took lately on a fresh split face was 23%. Makes a huge difference from what I was burning last year!If you just split and stacked that wood this year keep your current stove till spring unless you can confirm it has the right moisture content. It will burn it a lot better than an EPA stove. My wood is 18%-24% and I can easily tell the difference between the two ends of the spectrum. EPAs are picky from what I've read and now experienced a little for myself.
