Do Pellet Stove Gaskets Wear Out On The Door?
drizler
1,004
Chazy, NY 12921
I have had my Countryside since 2004 I know it's sealed at the pipe joints but keep thinking I get the wood burning smell more than I should. My one crime is that it has to be lit manually withl a propane turbo torch. Still, It seems like the smell never seems to dissipate over the hours of running like I would expect it would. So do you guys change yours every so many years, clean them ect? ;?;?
Take a strip of paper or dollar bill and close the door then pull the paper. If it gives sine resistance while coming out, should be good. Check various spots around the door. Sounds like it's time though.
I would start looking very hard at a exhaust leak! I have seen holes in that stoves exhaust fan housing too. So many areas to leak in the exhaust system.
Did you at any time bypass the vacuum switch?
There is no vac switch on that stove. Scary ain't it, and they still sell em:(
I think the babys and the T40s had vacuum switches. Not sure what exact model the OP has, unless I missed something.
Baby was introduced I think around or just after 04
The fire box is at negative pressure and, once the fire is going and the door is closed, it should not be possible to leak smoke out of the fire box. Leaks at the door seals or other seals on the fire box are to prevent air from entering the fire box and bypassing the fire pot. If the flame is active it unlikely that you have a significant leak there. If the vent and blower path is compromised (in need of cleaning) or if the blower is not functioning properly it is possible for smoke to leak from the fire box because the negative pressure is not adequate. You would know that is the problem because the flame would be lazy and possible sooty.
The path from the combustion blower out to the vent is at positive pressure so that is where you should be looking for leaks. The worst culprits, when it comes to leaks, appear to be elbows and cleanout T's.
Just replaced the tadpole gasket on the door of my 6-year-old Santa Fe, and it eliminated a smoke leak. The leak wasn't when the fire was going well, but when it was being ignited. As the pellets are catching the stove fills with smoke for a moment. Some of that was getting out. Not enough to see but enough to smell, and be slightly irritating. There's also a more effective air wash for the glass with the new gasket.
