R Mannino
Are they moving water? If the boiler is hot, ball valves are open, pumps pumping, you have heat.
Unless it has no water in it..............................................
How would you tell for sure that there is water running through them?
Is the pump moving hot water? Are the zones getting heat? Sounds like you have more than one issue - but there have been some questions asked more than once that haven't been answered yet.
Are the return pipes getting hot. Pump impeller could be gone, pump may be air bound. At this point you need a pro.
There are two issues that I can see from what you are posting. Your circulator isn't pumping water, and you have no control over your burner. But we don't know for sure about the circ - you say you hear it running. But there are no wires hooked to the C & Z terminals in the stat - and you still haven't provided any more info about how your circ is powered. And you can't tell if hot water is running through your pipes. Then, the stat settings should stop the burner from running when the boiler gets to setpoint. Not going back to reread now - but didn't you say you changed stats? Are you sure the sensor & sensor lead are still good inside the well? If that got broken, you won't control squat.
This has been an interesting flurry - but I need to go to bed now. Maybe it will be fixed when I come back tomorrow.
Can you verify that there is water in the boiler? I would suggest that you manually crack the pressure relief at the top of the boiler, but they sometimes don't close completely when you mess with them.
I'm guessing a bad motor on the burner. With power at B1 on the aquastat the burner should be running.
I am trying to keep up hold in there with me!
Water does seem to be heating the pipes and circulating but does not reach the tap system, it is as if it does not run long enough to fill the system.
The led sensor is fine as I replaced it.
I heeded that info, but when I initially tested those B terminals I did not have the system running, I simply had some of the electrical components powered on...
And this means exactly what?
Ok - what 'tap system'? What does that mean exactly?
I think you need to start over on some things you've said so far - each post brings more confusion. I went back to page 1 and you said more than once you had no power at L1 L2 but did at the Bs. That should not be possible. You either gave us bad info there, or have some really messed up wiring somewhere.
(I made it to bed but just had to bring this with me for some reason...)
