Blower for True North
sfogarty72
7
Maine
Does anyone have any thoughts or personal experience with these? I was thinking about adding one. My stove is off to the side of my house and the heat seems to stay in that room. I have been using fans in the other rooms pointing towards the stove room.
This is my permanent, temporary blower on my 27. I assume the blower attaches similarly on the TN. The drawing looks similar, but it doesn't have the extra piece that directs air more across the top of the stove.
If I used the stove every day, I would probably spring for the proper blower. Maybe you could try this to see if the blower will do what you want.
I did buy the blower. $220 shipped to my door. It took about 3 mins to install. Very easy. It works really good I think. Can be a taste noisy, but its in my man cave so it doesn't bother me. One thing I dont like is that when you turn it on it is variable speed (which is great) but is not heat-activated like the website says. So if fire goes out it just keeps running.
A limit switch can be added easily. They aren't very expensive.
Reactions: Tyler
You could do what I did and wire the receptacle that the blower plugs into on a wall switch and use a timer switch to operate the blower.
http://www.homedepot.com/p/GE-In-Wall-Digital-Countdown-Timer-15318/202788262
I picked up one of these at HD that has 5 15 30 60min and 2 & 4hr increments. Works good for me since I get about 2-4 hrs for most fires. They offer lots of these type switches in different increments. I just select the appropriate one I think is best upon start-up, before leaving or going to bed. Most of the time after I get the fire dialed in I turn the blower on with either the 2 or 4hr setting depending on the load (species, how full etc.) and let it go. Works great. A lot better than the blower running indefinitely while I'm sleeping or gone.
I built one for $35, Use a 6" duct boot from Menard's, clip edges, fold back, bolt to fan opening. I used a 6" duct booster fan. Only 127 cfm i think, Not a part your hair fan blower but a very slow, even and quiet heat output.
Reactions: Tyler
