Need some advice on gas conversion
Jaugust124
375
Mid-Hudson Valley, NY
Hi Everyone. Haven't posted on Hearth.com in quite some time. Hope everyone is doing well.
Anyway, I could use a little advice on which way to go with my oil to gas conversion.
Here's my set up:
I currently have a 2006 Dunkirk Empire 2 hot water boiler that heats our 2300 sq. ft. home and provides our hot water. Probably in the 80ish% efficiency.
Options I've looked into so far:
Option 1. Replace just the gun for about $3600 and keep hot water set up.
Option 2. Replace the gun and add a Super Stor for an additional $2400-$2800 depending on the model - glass tank vs. stainless steel tank. Total $6000-$6400
Option 3. Replace the entire unit with a high-efficiency Navian combi-boiler (heat and h/w) for $6200 and after getting a $700 rebate from the gas company, it brings down the cost to $5500. With a little luck, I could possibly sell old oil boiler and 330 gallon tank for maybe $500 for a little more savings.
Option 4. Replace the gun and add a 40 gallon gas hot water heater to my system and shut the boiler down in the warmer months.
The guy who suggested the Navian said I wouldn't see much of a savings by adding a Super Stor. He likened it to heating another room in the house.
Currently thinking that option 2 might be NOT the way to go due to cost compared to new boiler.
I plan to get more estimates and advice from some local installers, but I thought I would pick the brain of a few people here.
Thanks in advance for the advice.
Jamie
Wow, thought I would get a little feedback on this. I guess I was wrong. No thoughts?
For what my 2¢ is worth…
I personally would recommend option 3 just to have everything in one unit for simplicity sake. Most newer boilers have an option to only heat for h/w f when it is warmer. I don't see much argument for having separate units when you have a home heated by a boiler especially when your home already has an "all-in-one" unit.
These are pricy but well worth the money. It sounds as if you are doing a good job at shopping around before making the final decision. Keep us posted :)
I'm only a hacker homeowner, but $3600 just for a new gun seems excessive.
My neighbor showed me his quote for replacing the gun - $2500.
Thanks for the replies everyone. Still researching. If the price of oil keeps going down, I may just hold out until spring.
