Hi, I own an f600 and the air control stopped working. The lever moves as it should and I have removed cover to see the sliding mechanism it attaches to works as it should. Any ideas on where to look next???
I just bought a Jotul F600 and decided to break it in outside before i installed it. The fire will not burn without the ash pan lid open.Adjusting the air doesn't make any difference.I considered a draft problem since i don't have but about 24" of pipe on it ; but if that's the case then why does the ash pan lid work???Hi, I own an f600 and the air control stopped working. The lever moves as it should and I have removed cover to see the sliding mechanism it attaches to works as it should. Any ideas on where to look next???
Don't do this! You are turning the stove into a forge and stressing cast parts with the extreme and rapid heating of the grate and base. If there is damage the warranty may be void. With 24" of pipe on it there is no draft. Draft is the engine of the stove. The stove needs 16ft of flue to draft properly.I just bought a Jotul F600 and decided to break it in outside before i installed it. The fire will not burn without the ash pan lid open.Adjusting the air doesn't make any difference.I considered a draft problem since i don't have but about 24" of pipe on it ; but if that's the case then why does the ash pan lid work???
it still took over an hour to get the stove to 200 degrees; if there is no draft,which i agree, then cracking the ash lid just a bit is replacing the combustion air. I know I'm rerouting the air but if this stove is that sensitive why would i even want it? I'm just trying to burn off the exterior before i install it to keep that burnt paint smell out of the house.Don't do this! You are turning the stove into a forge and stressing cast parts with the extreme and rapid heating of the grate and base. If there is damage the warranty may be void. With 24" of pipe on it there is no draft. Draft is the engine of the stove. The stove needs 16ft of flue to draft properly.
