From my experience, even on large rounds, the first cycle yields 4 splits. The bottom 2 are usually ideal to go straight into the stack. The two halves have to be split again, which is normal even with the 2 way wedge except you have already gotten 2 splits off of the bottom. The distance between the horizontal wings of the 4 way and the main rail on the splitter is about 3 inches. Not quite sure if that description makes sense.I have thought off and on about fabricating one for my splitter but haven't yet. Mostly because it would only work well for a specific size round and switching back and fourth or digging for those rounds would seemingly slow me down.
That and with the Husky having the wedge on the ram and not the end would likely cause jamming. I think for it to work well I would need to fab up a flat ram and 3 or 4 way that clamps to the foot? This way the splits would spit out as you go.
You now have me thinking again
Exactly what I found.My Northstar 37 ton is made to use one, but I split mostly large rounds and I see it as more of a hassle than useful. If all you split is 8" to 12" rounds it would be a great time saver.
Sure, with a 37 ton splitter you can do anything you want, but I prefer not to use the 4 way so I don't end up with a bunch of odd sized splits. I prefer to quarter my rounds and then split the quarters in half and then throw them aside and then roll in another round. It is my preference to split all the rounds first while the splitter is vertical.Okay say you have a good sized round, like 24" diameter, can't you just run the 4-way wedge through it, throw the 2 small lower splits into the pile and than run the large top pieces through the wedge again? And do this again if needed. Why wouldn't this work, and be faster than a single wedge. Is it just easier to not use a 4-way wedge because there is no real rush?
Even with the way I split, I still end up with buckets and buckets of loose bark, wood shards and burnable debris. This is just how it works for me, I get into a splitting rhythm and don't like to stop and toss every little split.,Ya that is what I was wondering. It sounds like a 4-way wedge will overall be faster but you will end up with more odd splits - some even kindling sized.
thanks!!Excavator, It looks like you have the best of both worlds - you drive your bobcat to the big rounds and use the single wedge to reduce them down, and than use the 4-way to finish them off - nice set up.
