Had saw that uses Sawzall blades?
Knots
1,173
Alfred, Maine
Does anyone know of a small handsaw, like you'd use for pruning, that uses Sawzall blades? I hate to buy something with a blade that can't be replaced easily when it goes dull.
Not sure about sawzall blades but I have a Gerber multi-tool that takes the 3 inch replaceable jigsaw blades.
I also have a 21 inch bow saw that I use a lot for pruning that has a replaceable blade.
I've never seen a Sawzall blade that could hold a candle to a good pruning saw. Sawzall blades are thicker, and their teeth blunter. Have you had a pruning saw dull too quickly, or is this just something you're worried about?
Harbor Freight bow saws are pretty good and come with 2 blades. Cheap enough that when you go through both blades you just replace the saw. I've yet to go through one yet though, let alone use the replacement.
How small do you want? Like some others mentioned, bow saws are nice to have. I have my eye on a Corona pruning saw, but may settle for a Fiskars. The Coronal blades are replaceable. I wouldn't want to use a reciprocating blade by hand, seems like it'd be a lot of slow work.
What about using a cordless sawzall? :cool:
I have a Snap-on handle that uses Sawzall blades. Look at some place that sell drywall tools. I have seen several different company's that make them. I think they are called a jab saw.
Reactions: bobdog2o02
I can't recall the name but I have one. Looks like a switchblade knife, but with the sawzall blade.
Thanks for the replies. I probably should have been more specific. I've always wanted a fold-up saw (I have two bow saws) for putting in my back pack when walking the property lines. It's a long walk and occasionally some branches on the line need pruning.
I'd like something like this, but don't like to be tied in to a blade that's not easy to replace:
http://www2.fiskars.com/Gardening-a...e-Pruners-and-Saws/Folding-Saw-7#.VJHOEb-mRz8
The battery sawzall appeals to the Tim Taylor in me, but is a little too heavy for this.
Cool. Does it work good?
20141217_134812.jpg I forgot about the folder until it was mentioned. Both of these will take standard Sawzall blades.
Sweet. That's the kind of thing I was looking for. Thanks...
the blade is going to be the critical part for pruning. there used to be sawzall blades made for pruning, have not seen one in a while but have not really looked either.
I have both options.
The Milwaukee handle from Homie Depot and the pruning blade for my cordless sawzall.
I haven't used the handle for anything but stuff around the house. It serves it's purpose well, but I always find myself using the Sawzall with the appropriate blade. It's faster, and I'm lazy.
Pruning with the Sawzall is OK, but for anything bigger than 2-3 inches I'll just grab the chainsaw. It's much quicker.
You must have not seen these blades before:
That is what I use on my saws-all for pruning (and lots of other general wood cutting)
Reactions: TreePointer
Indeed, I had not, but I still wouldn't bet on them against a blade designed for handheld use. Probably cheaper, though. I have a Silky folding saw which is a thing of beauty, but replacement blades are about 70% of the cost of the whole saw.
They won't perform as well as a bow-saw would, but that's primarily because of length and the fact that if you really bear into them they can flex, whereas a bow-saw blade can't because it is in tension from the bow. They really are a really great blade. They are made entirely for wood, they have those fancy, super sharp double-bevel saw teeth and they slice right through easily. While it wouldn't be my choice for cutting firewood, or cutting a board for a project, they work great for pruning (that's what I mostly use them for) or otherwise just cutting wood for general purposes where angle/dimension don't matter.
Yep - that right there summarizes the whole thing. I want cheap(ish) blades that I can also use in a Sawzall. I don't need super performance, just good enough.
